  1. hi every one. i doing research work in HEVC h.265. and i need h.264 matlab code. plz help me
    swati_pak2003 on yahoo
  2. can any one tell me the procedure to use the hevc reference software
  3. Member Wolfen's Avatar
    Jun 2009
    Canada
    You can find manuals and even demo code out there just google it.
    Apr 2016
    USA
    Hi, I am encoding 10 frames of BQMall video test by using HEVC HM 15.0
    ../bin/TAppEncoderStatic -c encoder_lowdelay_main.cfg -c BQMall.cfg
    The problem is the bitrate achieved was 1079 bps and the runtime for encoding 10 frames was 59 sec, so, I think these results are not correct. This is the first time I am trying HEVC encoder. According to several papers HEVC achieves higher bitrates, so, am I doing something wrong?
    My machine is Intel(R) Xeon(R) CPU E5-2650 v2 @ 2.60GHz, 65933 MB
    Thanks,
