Have had issues with converting a Huffyuv file to Blu-Ray format with Vegas Pro 8. Would you anticipate any problems with this?
Results 1 to 10 of 10
Use the AVCHD encoder, and that's "consumer blu-ray", not "Hollywood blu-ray". I think you need version 9+.
Re-read my answer and jagabo's and budwzr's answer. In essence, all our replies say:
(a) Yes, Vegas can.
(b) what does huffyuv have to do with it?
(c) what do you mean by "glitch"?
But now that you have the solution, it's moot. Mainly, just asking that you be a bit more specific.
I appreciate your efforts to assist but I don't know why this particular point doesn't seem clear to you. I'm taking a HuffYuv file and converting it to a Blu-Ray compatible file. What it has to do with the Blu-Ray is it's the file that's being converted. It's an intermediate stage. I get that an over 300 gig file won't fit on a 25 gig disk. I never at any time said I thought Huff files in of themselves are Blu-Ray compatible. That's something you keep reading into it for some reason. If this doesn't straighten out your misconception of what I've actually been saying, I can't make it any more clear.
It gets to a certain point and stops processing. Always the same point in the file which leads me to think there's a problem with that particular file.(c) what do you mean by "glitch"?Last edited by brassplyer; 5th Dec 2012 at 08:09.
Thanks for clarifying the glitch. Don't know why the encoding would just stop at a certain point, but you seem to have solved the problem.
The difference between huffyuv or Lagarith compression and BluRay or MPEG encoding/compression is this:
huffyuv and lagarith are not "encoders", they're compressors; they are, for example, similar to ZIP or WinRAR. They don't rearrange the source into a different frame organization such a I, P, B frames (which are mainly partial images rather than full-data images), nor do they incur any data loss. BluRay/MPEG do make those rearrangements and have some degree of data loss involving different bitrates. The BluRay/MPEG compression and partial-image structure are the processing steps that convert a 300GB huffyuv/Lagarith video into a much smaller file. -
to find out if it was Huffyuv "glitch" you cut out a piece out of it in Virtual Dub, that particular part when Vegas stops and try to encode it , if Vegas goes through without problems that it is problem with Vegas export modul
Captured from BlackMagic Intensity Pro > convert to blu-ray
By necron99 in forum Capturing and VCRReplies: 1Last Post: 27th Apr 2012, 03:14 -
try to render file with HuffYuv video format on Sony Vegas, please help!!!
By byair74 in forum EditingReplies: 0Last Post: 15th Feb 2012, 04:28 -
Wanna convert Blu Ray Movie to Play on Laptop/PC without a Blu Ray PLayer !
By augustya in forum Blu-ray RippingReplies: 5Last Post: 13th Aug 2011, 04:35 -
Convert MTS files to DVD or BLU RAY format
By flix in forum Video ConversionReplies: 4Last Post: 21st Apr 2010, 22:03 -
how can i convert file mpeg4 in blu ray disk
By gofresh in forum Authoring (Blu-ray)Replies: 4Last Post: 1st Mar 2009, 20:52
