Results 1 to 19 of 19
    Dec 2012
    Hi,
    When I downloaded MPEG2 StreamClip for PC, I did not get the following, volume or slider (or scrubber). I have the correct version of quicktime alternative installed. I've tried this on the Laptop and PC. Here's a screen shot of it:
Name:	MPEG STREAM CLIP SCREEN SHOT.png
    Thanks for your help,
    Patsaw
  2. seekbar slider or volume controls won't appear until you have a video loaded
    Oct 2005
    666th portal
    that's all there is to the program load screen. you are not missing anything.
    Dec 2012
    Thanks for the reply but they don't appear even after the video is loaded and I can't get any audio when the video is playing through MPEG Stream Clip.
    Dec 2012
    Here's a screen shot with video loaded into MPEG2 Stream Clip:
Name:	MPEG STREAMCLIP WITH A LOADED VIDEO.jpg
    Thanks,
    Patsaw
    Oct 2005
    666th portal
    try installing the latest beta version.
  7. Originally Posted by aedipuss View Post
    the 1st screenshot shows the latest beta 1.2.1b6
    Maybe there is something wrong with the test file ? Did you try other file types ? Although it mpg - it says DVD video recorder - sometimes they record non standard filetypes
    Dec 2012
    I did not try another file. However, there is someone else in our building that is working on these same DVDs and they have had all of the controls of the program show up. Here's a screen shot of her MPEG2 Steam Clip:
    I've tried BOTH versions of MPEG2 Stream Clip on all computers and get the same results.
    Here's a look at the files from one of the DVDs:
Name:	DVD FILE STRUCTURE.jpg
    Any setups in MPEG2 Stream Clip or QuickTime Alternative I should double check?
    Thanks,
    Patsaw
  9. I'm a MEGA Super Moderator Baldrick's Avatar
    I just tried both mpeg streamclip 1.2 and 1.2.1 beta 6 with quicktime alternative 1.81. Same bug. And I'm also running win7 64 bit.
    BUT the hidden scrubber works, try drag in the black area at the bottom...
    Dec 2012
    Hi Baldrick,
    Thanks, I tried dragging in the black at the bottom. However, this is very cumbersome and I still have no volume control. Thus, I am also not able to hear the audio in MPEG2 StreamClip. Can you hear it? I am able to hear the audio when I play the DVD in Windows Media Player.
  11. I'm a MEGA Super Moderator Baldrick's Avatar
    Nope, no audio.
    Maybe time to find another editor.
    Dec 2012
    Here are the specifications on my Laptop and Desktop PCs:
    Laptop PC Details
    -Opperating System: Windows 7 Enterprise 64 Bit (Service Pack #1)
    -Processor: Intel Core i7 Q820 @ 1.73GHz 1.73GHz
    -RAM: 8GB
    -Video Card: ATI FirePro M7740
    -HDD: 464GB
    Desktop PC Details
    -Processor: Intel Core (TM)2 Duo CPM E8400 @ 3.00GHz 3.00GHz
    -RAM: 4GB
    -Video Card: ATI Radeon HD 2600 XT
    -HDD: 232GB
    There is no driver update available for either video card driver.
    Baldrick,
    Any suggestions on different editors to use?
    Dec 2012
    Here are some screen shots that might help:
    QuickTime Alternative Options
    Player Formats
Name:	QTA PLAYER FORMATS.jpg
    Playback Output
Name:	PLAYBACK OUTPUT.jpg
    QuickTime Configurations (I find this folder but QuickTime is not installed)
    Preferences-Audio
Name:	QTP AUDIO.jpg
    Preferences-Advanced
Name:	QTP ADVANCED.jpg
    Cor AVC Properties
Name:	COR AVC PROPERTIES.jpg
  14. I'm having the same problem. Does anyone know how to fix this?
  15. Maybe use actual quicktime?
    No problems here, 64bit Win 7, Streamclip 1.2
  16. I asked somewhere else for help and was advised to install a codec pack from http://codecguide.com/download_k-lite_codec_pack_mega.htm but that didn't work.
  17. Anybody ... ? I'd really appreciate some help.
  18. I'm a MEGA Super Moderator Baldrick's Avatar
    Nope. No solution. Use something else to edit.
  19. Originally Posted by Baldrick View Post
    Do you have any suggestions?
