Is there any way that DVD-Lab Pro can recognizes subtitles to be italic? <i> doesen't work, you can do it by hand but it takes forever.
Any tips on that?
Yes, feed DVD-lab PRO with SST files. MaestroSBT can generate .SST from .SSA.
Got it to work now, ended up perfect! Thanks for the tip mate.
When I generate the BMP files, the subtitles has black outline. But when I open them in DVD Lab Pro the outline disappears. What to do?
Is there an easier way to keep the italic subs in DVD-Lab Pro?Last edited by walruss; 20th Dec 2012 at 20:07.
[DVD Lab Pro] subtitles wrong time
By dom61 in forum Authoring (DVD)Replies: 2Last Post: 4th Sep 2011, 08:42 -
DVD-Lab Pro Subtitles Encoding troubles
By laste in forum Authoring (DVD)Replies: 1Last Post: 16th Jan 2011, 15:12 -
DVD-Lab Pro: Subtitles change text
By TheLaserdisc in forum Authoring (DVD)Replies: 8Last Post: 18th Aug 2010, 13:23 -
TMPGEnc DVD Author 3.0.5.149 - subtitles with italic commands
By lienny in forum Authoring (DVD)Replies: 9Last Post: 20th Jan 2009, 21:27 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14
