I wrote a blog post about this: http://www.thethrillness.com/2014/01/1080p60-lossless-capture.html
				Results 61 to 77 of 77
	Someone reliable has told me that the ExtremeCap U3 incorrectly records everything at 1080p60.00 despite being set to 1080p59.94 and being fed a 59.94 signal. I wonder if the extra duplicate frames can be easily excised with Avisynth.
 This is similar to the problem with a previous AVerMedia model, the C127 PCIe card, which recorded 59.94 fps sources at 1080p30.00. (No one else cared.)
	The dupe will be 100% identical with YCbCr input, at least.
 TDecimate with sdlim=1000?
	Nothing is ever 100 percent identical with analog input. And with film based material there will be many many duplicate frames. With games there will be duplicate frames any time the rendering frame rate drops below 60 fps.
 I don't think TDecimate will work with cycles that large. Maybe with 2 pass decimation? You can test this for yourself by making a video with a duplicate frame every 1000 frames.
 You'll still have a jerk from the duplicate frame. And you'll have to adjust the audio length.
 <edit>
 I just checked. TDecimate will work with 1001 frame cycles. At least with small frames:
 I'll leave it up to someone else to try it with 1920x1080 frames!Code:ColorBars() #640x480 AssumeFPS(60000,1001) # 59.94 fps ConvertToYV12() # for TDecimate later ShowFrameNumber() # unique frame number on each frame ChangeFPS(60) # duplicate 1 frame every 1000 TDecimate(cycle=1000, cycleR=1) # locate and remove the duplicate Last edited by jagabo; 27th Jan 2014 at 23:37.
	we need an actual sample from the hardware being discussed in order to test these theories. the one mentioned was from another forum board discussion and the samples were removed.
	Yes, it would be nice. Unfortunately I haven't been able to get this guy to send a sample along.
 YCbCr is digital! I was talking about HDMI captures. I'm unsure about whether it would be a 100% dupe with an RGB source since the two AVerMedia cards that I have add dithering.
	There are so many now. They basically fall into 4 categories:
 1. Cheap ($130, h264 encoding) Elgato HD60 type: http://www.ebay.com/itm/Elgato-Game-Capture-HD60-Xbox-One-360-Playstation-4-PS4-Wii-U-...item3cf9534dd1
 2. Mid-Cheap ($160, compatible with hdcp streams) Aver ExtremeCap U3 type: http://www.ebay.com/itm/AVerMedia-ExtremeCap-U3-CV710-1080p-60fps-Capture-Uncompressed...item2c9d19e500
 3. Middle ($300-$315, linux compatible) Velocap U1 type: http://www.ebay.com/itm/Velocap-U1-HDMI-DVI-1080P60Hz-USB3-2-Video-Capture-Card-Mac-Li...item28022628aa
 4. High End ($400-$415, linux compatible, h.265 encoding, doesn't need very fast computer, compatible with hdcp streams)
 Shenzhen MINE type:
 http://www.aliexpress.com/store/product/MPEG-4-AVC-H-264-H265-HDMI-Encoder-Replace-HD-...364544617.html
 In the future, look for h265 recording boxes to become available with a usb otg port so a computer is not necessary.Last edited by ezcapper; 4th Aug 2015 at 23:13.
	New challenger is AVerMedia Live Gamer Extreme (GC550 - $170, Windows Only) - http://www.amazon.com/AVerMedia-Extreme-GC550-Stream-Design/dp/B00Y3U01RU
 Capture in 1080p 60fps Uncompressed Video via USB 3.0
 HDMI Pass-thru with Ultra-Low Latency
 Personalized Cover Image
 Audio Mix-In
 Support PIP and Live Editing with RECentral V2
 Its have full DirecShow drivers and works on Virtualdub, AmarecTv or any DS application.
 Claudio
	AVerMedia improperly captures 1080p59.94 as 1080p60.00 with duplicate frames.
 The StarTech USB3HDCAP offers more versatility (HDMI, DVI, VGA, component, S-Video, composite) for about the same price ($170-185). You do lose out on the HDMI passthrough, but I consider an HDCP-stripping splitter to be a virtual requirement anyway.
 Don't consider this a personal endorsement though. I've barely started playing with the thing.
	Hi.
 I bought that AVerMedia Live Gamer Extreme (GC550-LGX) in order to be able to do 60 fps capture of both my games & camera.
 I did not manage to make it work: it doesn't work at all on my streaming PC (Z68 chipset with Renesas USB3 ports, on which the ExtremeCap U3 is working just fine). And on my new PC (Z170 chipset with Intel USB3.1 ports) it works sometimes at boot time, but hangs very quickly.
 And anyway, you can't just use two AverMedia capture devices on the same system: as soon I connect the other, the first hangs.
 So back to my crappy (but working) Elgato Game Capture HD (with its 1.5s delay).
 Now, that "issue" with the 59.94 ips issue with AverMedia is a bonus for me, and that's why I'm still using it. The LGX would have allowed me to remove the HDMI splitter, and use my ExtremeCap U3 for the camera (both at 60fps). But anyways. The point is I have games that run at 60 Hz only: I can't force them to 59.94, it's 60.0 Hz and nothing else. So my game capture is at 60 ips. And so, I use the AverMedia for the camera so that it outputs also a clean 60 ips (from my GH4 59.94 signal). In my case, that "issue" with duplicate frames is just a nice solution for my setup.
 In the end, I still stream at 30fps, because I use the Elgato Game Capture HD for game capture ... which is only 30ips. Anyways... works.
 (it was a real pain to sync the camera & game images & game sound & microphone sound... took me 2 days to sync to the frame)
 BTW in case anyone is trying to use also a AverMedia Extreme Cap U3 with an Elgato Game Capture HD at the same time, here are my settings (on Open Broadcaster Software):
 AverMedia Extreme Cap U3 used for camera capture (GH4 in 4K mode / HDMI output downscaled to 1080p)
 Elgato Game Capture HD used for gaming pc capture (1080p60 image; 30 ips capture)
 microphone sound from MOTU audio interface (firewire; latency <1ms)
 Timings:
 Mic Sync Offset = 1233 ms (to sync the microphone sound with game capture)
 Camera buffering = 1066 ms (delay difference between camera & game capture)
 Audio Sync on game capture device = 733 ms (to sync game sound with game capture)
 With those all is sync to the same frame, under 10ms (both images / both sound streams).
 (which, in the end, is even better than the live display: the final stream is better synced what I have in my headphones, hehe ...)Last edited by Zetmor; 12th Oct 2015 at 08:27.
	Very nice infos Zetmor.
 I dislike ANY USB Capture card. No way.
 My recommendation to capture 1080p@60 is Intensity Pro 4K.
 Claudio
	Found on AVerMedia @AVerMediaGZ twitter:
 Originally Posted by LBPNATION @LBPNATION 4:34 PM - 3 Dec 2013And the direct URLs are (if permitted here):Originally Posted by AVerMedia @AVerMediaGZ 4:37 PM - 3 Dec 2013
 http://gamerzone.avermedia.com/support/download/extremecap_u3#application_and_driver
 https://s3-us-west-2.amazonaws.com/avermedia/web_release_www/C877/CV710_RECentral_1.3....3_20151210.exe
 Also I see here older bundle for w8.1 (also beta):
 http://gamerzone.avermedia.com/support/download/extremecap_u3#recentral_beta
 https://s3-us-west-2.amazonaws.com/avermedia/web_release_www/Beta/RECentral_13112102_7...31202_beta.zip
	That was a random bump, but thank you.
 Looking at the Mac user manual for the software confirms that the tool cannot be used to check whether one's motherboard is compatible before buying the device.
 Looking at the Windows user manual, it appears they have removed the option altogether.Originally Posted by CV710 user manual, Speed Test section: step 1
  1080p60 8 audio channels HDMI capture cardBy stereoactivo in forum Capturing and VCRReplies: 7Last Post: 6th Mar 2013, 04:24
  VHS Capture Card - Updated Recommendations?By Hessian in forum Newbie / General discussionsReplies: 3Last Post: 16th Oct 2012, 09:49
  Capture card recommendations?By dougieex0x in forum Capturing and VCRReplies: 1Last Post: 10th Jan 2011, 00:45
  New capture card recommendations with some specfic features?By justin81 in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2009, 13:00
  HD Capture - Any way to convert from 1080p60 to 1080p24?By Corvius in forum Capturing and VCRReplies: 4Last Post: 8th Nov 2008, 07:16
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
			 Visit Homepage
				Visit Homepage
