  1. I understand that AVS4YOU has a bad reputation for quality but I was wondering if the MPEG2 encoding worked anywhere near as good as TMPGE? I already own AVS4YOU and was trying to save some money for a few AVI files that I need to encode to MPEG2. I already tried the "hey honey which one of these looks better test" on my TV and couldn't really see much of a difference. Does anyone have any experience with the AVS4YOU MPEG2 encoder?
    I would use the free avstodvd. It can output as mpeg2 or dvd directly. And using one the best mpeg2 converters, hcenc!.
  3. Thanks Baldrick. I tried AVStoDVD and it seems to work really well. I can output to mpeg2 and then author with VideoReDo. Interestingly enough, I tried my AVS4YOU and it worked okay. However, there is not an option to not deinterlace so I think it deinterlaced automatically. I checked the mpeg2 file after converting with AVS4YOU with Gspot and it says progressive. Not sure if progressive is a big deal or not. I'm going to author to DVD and watch on TV. Original source file is home movie MiniDV cassette captured with firewire using WinDV.
    Feb 2008
    India
    Go in for the new freeware video to video converter that has got excellent encoding quality and it is churning out dvd compliants files too.
