Results 1 to 18 of 18
  1. Member brassplyer's Avatar
    Apr 2008
    I've been trying various Virtualdub deinterlace filters but find that with all of them, residual artifacts get left behind. I try a difference deinterlacer or setting and one part of the video looks better but it introduces issues in another part. Lines/jaggies around eyes, mouths, backs of jackets, shiny metallic surfaces etc. I can't seem to find a deinterlacer/setting that eliminates all issues.
    Is there such a thing as a deinterlace filter that makes the video look like it was shot progressively?
    What I'm focusing on at the moment is VHS transf'd via firewire and converted to HuffYuv.
  2. No, there are no great deinterlacers for VirtualDub. About the best you're going to find is Yadif. But it doesn't come close to QTGMC() in AviSynth. Even at its preset="ultra fast" settings QTGMC is better than anything in VirtualDub.
  3. Member brassplyer's Avatar
    Apr 2008
    The mediafire links to this on avisynth.org
    http://avisynth.org/mediawiki/QTGMC#Links:
    get warnings from McAfee siteadvisor. Any suggestions?
  4. I don't know why McAfee doesn't like it...
  5. Member brassplyer's Avatar
    Apr 2008
    What version of avisynth does this require? I have 2.5.8 currently.
  6. Banned
    Nov 2005
    isn't that a bit of a dubious statement? from what i have read qtgmc with the "ultrafast" preset uses yadif for deinterlacing, so if you can use yadif with v-dub then there's no advantage in switching to qtgmc with the ultrafast preset.
    also, from what i can see from poking around the qtgmc script all it really amounts to is using someone else's deinterlacer + sharpening and a few other tweaks, couldn't one just chain a bunch of similar filters and settings in v-dub or similar editing program and get the same results.
    i guess basically what i'm asking isn't qtgmc a tad overrated?
  7. 2.5.8 should be fine. I recommend you get the "plugin package with all requirements" if you don't have a lot of AviSynth filters already.
  8. Member brassplyer's Avatar
    Apr 2008
    I'm pretty much an Avisynth noob. I've fooled with it before but am being reminded of why I found it to be a pain to use.
  9. Banned
    New York, US
    No.
  10. Banned
    New York, US
    Many advanced users suggest that McAfee itself is as bad as a virus. You mean you don't recall a short time back when their "free" scanner thought Google's home page was a Trojan?
  11. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    And isn't the CEO wanted for murder?
    Mar 2011
    Nova Scotia, Canada
    Yes, and I think he may have been caught. Not 100% on that though. Bizarre story.
    Actually many antivirus programs give you a lot of false positives. One of the tech support people at the local university, where all students have to own a laptop and they are very integrated, told me that mse is the only one that's never screwed up on the network.
  13. Originally Posted by brassplyer View Post
    Is there a Virtualdub deinterlacer that doesn't leave residual artifacts?
    And just to be clear: there are absolutely no deinterlacers that deliver artifact free results. And there never will be. You can't create a full picture from half a picture without "guessing" what is missing.
  14. Originally Posted by budwzr View Post
    OT: Is he still the CEO? I thought he sold the company years ago and basically retired on some island ?
  15. Member budwzr's Avatar
    Apr 2007
    City Of Angels
    OK, then "founder".
  16. Member brassplyer's Avatar
    Apr 2008
    Having finally gotten it up and running and seeing the results, it doesn't seem overrated to me. As previously advertised, much better results than anything I've managed to get out of Vdub deinterlace filters.
  17. Banned
    New York, US
    QTGMC usually works well at its default "presets", but there must be 50 parameters you can play with -- when you need it. Note that most of the secret magic words are in the .avsi script; if you double-click it and try to open it as text, it looks like a binary file. Just open it in Windows Wordpad and save an extra copy as *.txt.
    The designer states that originally QTGMC was just for deinterlacing and repair of badly deinterlaced video, but somehow a lot of excellent denoising was required in the process. So QTGMC is also a pretty good denoiser in some respects (although according to the script you can preserve the noise, if you wish!). I use it to repair really bad VHS interlacing and other problems. Or to deinterlace for running AVisynth plugins that work progressive-only, but I reinterlace afterwards. If my original source is interlaced, I archive it that way: once you deinterlace the source and discard the interlaced original, your limited to progressive-only encoded formats forever.
    Get inside the actual script as a .txt file and you'll see that it's more than just a pretty face. The HTML help that comes with it only scratches the surface.
  18. Member brassplyer's Avatar
    Apr 2008
    Doing further experimenting, I continue to be impressed. Just the basic clarity of the resulting image is so much better than what I was getting before, I find I don't even need some of the Vdub filters I was using previously to tweak the deinterlaced image - seems they were just compensating for some of the shortcomings of the other deinterlacers.
