I have a 7Gb file in MKV format and need to play it on a PS3. The problem is that my PS3 would not recognize a USB drive formatted in NTFS. Furthermore, a FAT32 drive can only store files upto the 3.99Gb mark.
Here are the file details via MediaInfo:
Format : Matroska
Format version : Version 2
File size : 7.17 GiB
Duration : 2h 14mn
Overall bit rate : 7 623 Kbps
Video
Format : AVC
Format profile : High@L5.0
Codec ID : V_MPEG4/ISO/AVC
Audio
Format : AC-3
Format/Info : Audio Coding 3
Codec ID : A_AC3
I've attempted to convert using a software called PS3Muxer (LINK), however the end result is a bunch of mt2s files. I selected the FAT32 option under the "Splitting" menu.
The PS3 has LONG been surpassed as a media player for reasons like this. You could just buy a real media player like one of the Western Digital models and have something that understands NTFS format drives or you can continue to paint yourself into a corner with the PS3 and its many restrictions.
Load the mkv into tsmuxer and change level to 4.1 and save as a m2ts and load that into multiAVCHD and output as sony playtation 3,right now the file is high profile 5.0 and needs to be 4.1 to be able to play.
I loaded the file with TSMuxer and an error window popped up saying invalid H264 NAL unit size. NAL unit truncated.
I carried out a search for this on Google i came across the following solution:
"Hi, I too am having this problem. You can fix this without knowing about NAL, if the cause of your problem is in fact the version of MKVtoolnix, because it was for me. I muxed all sorts of movies in mkvtoolnix version 3.0, and then sent these through mkv2vob to view on playstation. I was stupid enough to think that an upgrade might actually be a good thing, so I upped to 4.3 of mkvtoolnix and now I can't do anything. to check what version your mkvs are, download mkvinfo. If they are in fact 4.2 (or later for sure, but not sure how far past 3.0), then use an older version of mkvmerge to create a new mkv. you should be able to drag your problematic mkv into the mkvmerge gui, remux it into a practically identical mkv, and then continue as planned in tsMuxer or mkv2vob or whatever your choice may be. I hope this helps. "
After using version 4.0.0 to create a new mkv file, it then loaded correctly. I changed the level to 4.1 and selected the M2TS Muxing option, and started muxing. The following error came up:
SmartLabs tsMuxeR. Version 1.10.6 http://www.smlabs.net
Decoding H264 stream (track 1): Profile: High@5.0 Resolution: 1920:800p Frame rate: 90000
Change H264 level from 5 to 4.1
H.264 stream does not contain fps field. Muxing fps=90000
H264 bitstream changed: insert nal unit delimiters
H264 bitstream changed: insert pict timing and buffering period SEI units
Decoding AC3 stream (track 2): Bitrate: 640Kbps Sample Rate: 48KHz Channels: 6Last edited by suleman1uk; 2nd Dec 2012 at 20:50. Reason: spelling
Problems converting recent mkv's to ps3 format!??
By josetjr in forum Video ConversionReplies: 1Last Post: 25th Sep 2010, 07:15 -
mkv with 2 languages into PS3 compatible file using mkv2vob
By fairwind in forum Newbie / General discussionsReplies: 1Last Post: 22nd Jan 2009, 16:11 -
By fairwind in forum AudioReplies: 1Last Post: 22nd Jan 2009, 16:10 -
Converting mkv with 2 languages into PS3 compatible file using mkv2vob
By And007 in forum AudioReplies: 0Last Post: 2nd Nov 2008, 07:06 -
Software that converts .AVI into PS3 compatible format
By dec60228 in forum Newbie / General discussionsReplies: 3Last Post: 15th Feb 2008, 09:27
