*gig* Why are you making screenshots of the window instead of using the 'Save Image'-button in the right corner?
Did you try to lower the sRestore speed&Thresh?
Other than that no clue, since as far as I see it this is a scene from a clip I haven't looked at.![]()
Results 151 to 156 of 156
It was saving as a png or something instead of a jpeg - force of habit.
The scene was just another couple of seconds past the main clips uploaded yesterday (it's the same scene though), the reason why the frame count might be higher is because it was taking from the full episode as opposed to the short sample uploaded, that's all. -
Hmmmmm, now it's getting a little more interesting!
The attached (new) sample is the result of inputting a short m2v sample of the original .vob and applying:
Code:QTGMC='custom' 'input type'=0 'Sharpness'=0.2 'Lossless'=before resharpening 'final temporal smoothing'=2 'Source matching'=2xrefined 'EZKeepGrain'=1.00 'Noise Preset'=medium 'Order'=0 (BFF) 'Preset'=slower SRestore Frate=25 + all defaults except ‘speed’= '-25'
This is a definite improvement though, compared to the previous (old) test run - which is also attached. Didn’t think the ‘custom’ would make such a difference and I’m not sure on some of the selections I made (not all have a tooltip associated with them), but it’s defo looking better at last. -
.....And what I mean by 'looking better' is just the field jerkiness at the very start (first 3-4 seconds) - I don't mean the picture quality or anything, that's fine.
btw. -25 might be a bit overkill
will add tooltips for the next version if you tell me which options are lacking tooltips
the package from: http://www.mediafire.com/?su7l5jtcobabksk includes a html with further explanations.
how to change frame rate on staxrip?
By VistaXP in forum Video ConversionReplies: 6Last Post: 6th Apr 2011, 14:13 -
Need Help With StaxRip Settings For Exact Quality?
By skorpinok in forum Video ConversionReplies: 1Last Post: 29th Aug 2010, 11:36 -
staxrip & volume control
By Danneauxsvh in forum Video ConversionReplies: 0Last Post: 4th Jul 2010, 09:17 -
Which settings for StaxRip and DVD => mkv (x264) ?
By QUEENFAN in forum DVD RippingReplies: 1Last Post: 23rd Dec 2009, 12:34 -
Best settings for VHS Rips useing STAXRIP
By contactadam2002 in forum Video ConversionReplies: 3Last Post: 25th Jun 2009, 17:33
