Please , could someone help me to how to go about converting my PAL Vhs tapes on to DVDs. I am not conversant in IT and softwares, so please not too technical. BTW , PAL is the system i was using in the UK , and my tapes do no longer work now that i am in CANADA.
Thanks for your kind help. Awaiting.
Exactly how many tapes do you REALLY need to convert? If you're talking about perhaps 5 or fewer, it might be in your best interest to just pay a video shop in your town to do the conversion for you. If you have a lot of tapes that you really and truly cannot live without and can't afford to pay others to do the job for you, you'll have to invest many hundreds of dollars in equipment - a converting VCR, a DVD recorder and possibly a TBC (time base corrector). Converting PAL VHS to NTSC DVD is quite complicated and given your constraints, it may be more than you can really handle.
Capture as PAL to your computer and then convert to NTSC. The ADVC boxes can easily do the PAL capture from a PAL VHS. Avs2DVD can do the conversion (I think).
Or, convert the PAL to NTSC on the fly with something like this:
http://www.220depot.com/Com-World-CMD-1500-Professional-PAL-NTSC-SECAM-Video-Converter.html
Be warned, though, they do a lousy job of it. Then, once as NTSC on the computer, convert to DVD. Or use it in combination with an NTSC DVD-Recorder to get NTSC DVDs quickly. The result will be even worse. Depends on how badly you want decent quality. If you want them as good as possible, then you'll need both equipment and knowledge. Apparently you have neither.
NTSC VHS conversion to PAL DVD where can I buy a combo player
By Wizard81 in forum Capturing and VCRReplies: 10Last Post: 6th Apr 2012, 12:55 -
Capturing NTSC tapes on PAL VHS and DVR
By ramrod1234 in forum Capturing and VCRReplies: 0Last Post: 23rd Oct 2009, 22:08 -
Restoring VHS tapes with a mix of NTSC and PAL-M encodings?
By leon43 in forum RestorationReplies: 5Last Post: 24th Nov 2008, 06:31 -
Newbie needs to convert NTSC VHS tapes to PAL DVD
By mcullen8320 in forum Newbie / General discussionsReplies: 3Last Post: 13th Nov 2008, 14:51 -
Capturing NTSC VHS tapes to PAL Final Cut...
By willed in forum Capturing and VCRReplies: 2Last Post: 22nd Jan 2008, 17:48
