I'm trying to make an AVCHD out of mp4 files created with a samsung HMX-W200 camcorder. When trying to use MultiAVCHD it gives an error
So I tried using tSMuxer GUI and it gives meCode:[07:28:48] Initialising... [07:28:48] Checking for new version... [07:28:51] You have the latest build. [07:28:51] [04/07/2012] build 771 (latest is: 771) - Few minor fixes (runtime/line 109 errors). Changed handling of some rare flavours of video in MP4 container. [07:28:51] Consistency check finished! [07:28:51] Initialization finished. multiAVCHD is ready! [07:28:51] 3 years and 338 days since multiAVCHD was published. [07:28:51] 516 people supported it with donations [07:28:51] and you are the 7890 one to launch the program... [07:28:51] Support multiAVCHD to extend its features and keep it going! [07:28:51] multiAVCHD.dat version: [04010767] [07:29:04] Checking for available space and drive types (FAT32/NTFS)... [07:29:15] Destination [c:]: NTFS, 6979.72 MiB (6.816 GiB) free space [07:29:15] Temp folder [c:]: NTFS, 6979.72 MiB (6.816 GiB) free space [07:29:15] Log started for multiAVCHD v4.1 (build 771) [07:29:15] Selected output mode: Playstation 3 (USB/SDHC/MS) [07:29:15] Processing one title... [07:29:15] Existing c:\multiAVCHD\AVCHD\ cannot be used as destination folder! [07:29:15] Output will be written to: c:\multiAVCHD\AVCHD-20121128-072915 [07:29:15] Processing (E:\VIDEO\100VIDEO\HDV_0009.MP4.M2TS)... [07:29:18] Detected frame reference count: 0 (max:4). [07:29:18] Detected video: ID#256:V_MPEG4/ISO/AVC 1920x1080, fps=29.970, ref=0 [07:29:18] Adding AC3 audio track (ID#257) [07:29:18] Total of 2 tracks found in this file. [07:29:18] Creating clip and playlist info (tsMuxeR)... [07:29:18] Media split set at 4000MiB point... tsMuxeR (Version 1.10.6) output: =============================================================================== Decoding H264 stream (track 1): Profile: Main@4.0 Resolution: 1920:1080p Frame rate: 29.97 H.264 stream does not contain fps field. Muxing fps=29.97 Decoding AC3 stream (track 2): Bitrate: 256Kbps Sample Rate: 48KHz Channels: 2 =============================================================================== =============================================================================== tsMuxeR meta: =============================================================================== MUXOPT --no-pcr-on-video-pid --new-audio-pes --blu-ray --vbr --custom-chapters=00:00:00.000 --split-size=4000MiB --vbv-len=500 V_MPEG4/ISO/AVC, "E:\VIDEO\100VIDEO\HDV_0009.MP4.M2TS", insertSEI, contSPS, track=256, fps=29.970 A_AC3, "E:\VIDEO\100VIDEO\HDV_0009.MP4.M2TS", track=257, lang=und, timeshift=-6ms =============================================================================== [07:29:19] Important files missing (clpi/mpls/m2ts)... [07:29:19] Possible tsMuxeR failure to process your input file (E:\VIDEO\100VIDEO\HDV_0009.MP4.M2TS). [07:29:19] M2TS (media) file count: 1 [07:29:19] CLPI (clipinfo) file count: 0 [07:29:19] MPLS (playlist) file count: 0 [07:29:19] Skipping to next... [07:29:19] ERROR: Compilation does not contain any HD-DVD/AVCHD/Blu-ray titles! [07:29:19] Setting pop-up menu... [07:29:19] *** Completed! [07:29:19] Preparing menu pages... [07:29:19] Setting main menu for 0 titles... [07:29:19] Selected TV system: [NTSC] [07:29:24] Done! Compilation summary: Format: Playstation 3 (USB/SDHC/MS) Name : multiAVCHD =============================================================================== =============================================================================== Output size : 0 MiB (0 GiB) [07:29:24] Warnings/errors for this compilation: 1 [07:29:24] c:\multiAVCHD\AVCHD-20121128-072915 folder created (AVCHD/Blu-ray output)! [07:29:25] Copy c:\multiAVCHD\AVCHD-20121128-072915 to root of USB stick/disk or MemoryStick card or to X:\PRIVATE\ of SDHC/SD/MMC card and rename to AVCHD! [07:29:26] You may now remove temp folder (c:\multiAVCHD\_TEMP\multiTEMP-20121128\). [07:29:26] multiAVCHD finished in 11.016 seconds (00:00:11.016)! [07:29:26] End of log.
and on the top of the window it saysCode:Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bad SEI detected. SEI too short Bitstream exception Unknown exception. It does not have to be! Plase contact the application support team for more information.
Here is what MediaInfo says about the file:Code:tsMuxeR finished with error code -3
I read about this possibly being an issue with missing header info but I tried the "fix" listed here but it didn't fix my problem. Same thing happens. Any help is GREATLY APPRECIATED!!!!Code:General Complete name : G:\VIDEO\100VIDEO\HDV_0009.MP4 Format : MPEG-4 Format profile : Sony PSP Codec ID : MSNV File size : 27.9 MiB Duration : 14s 481ms Overall bit rate : 16.1 Mbps Encoded date : UTC 2012-05-05 00:15:59 Tagged date : UTC 2012-05-05 00:15:59 @sec : UNG Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : Main@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=8 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 14s 481ms Bit rate mode : Variable Bit rate : 16.0 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.257 Stream size : 27.6 MiB (99%) Encoded date : UTC 2012-05-05 00:15:59 Tagged date : UTC 2012-05-05 00:15:59 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 14s 464ms Bit rate mode : Constant Bit rate : 128 Kbps Channel(s) : 1 channel Channel positions : Front: C Sampling rate : 48.0 KHz Compression mode : Lossy Delay relative to video : 33ms Stream size : 226 KiB (1%) Encoded date : UTC 2012-05-05 00:15:59 Tagged date : UTC 2012-05-05 00:15:59![]()
Maybe you could try remux the mp4 to a mkv with mkvmergegui and see how multiavchd handles the mkv. Turn off header compression in mkvmergeui also(under file->options->disable header compression).
Or try avchdcoder if you haven't already. -
I ended up just unchecking one of the two options for tsmuxer in the settings tab of MultiAVCHD. That seemed to fix my issue. On a side note however, can't remember if this is related but I used eRightSoft's SUPER to copy the video stream and encode the audio stream to ac3 in a .TS container. Works really well, although SUPER comes with some adware that you can remove, it's a very powerful application.
Tsmuxer error.
By benson733 in forum Authoring (Blu-ray)Replies: 8Last Post: 31st Aug 2012, 16:37 -
Help with tsMuxer!!
By BIGD22 in forum Blu-ray RippingReplies: 5Last Post: 29th Oct 2011, 21:01 -
tsMuxer Help Please!!!
By zzNyQuilzz in forum Video ConversionReplies: 3Last Post: 26th Sep 2011, 08:17 -
TSmuxer error
By kings322 in forum Blu-ray RippingReplies: 0Last Post: 3rd Jun 2010, 15:43 -
tsMuxeR GUI eats all available RAM
By toddvj in forum Blu-ray RippingReplies: 20Last Post: 26th Nov 2009, 18:43
