So, today I decided to do a backup colpy of my system, in case my machine fries and I donīt wanna go through the hassle of installing every drive and program again.
Havenīt done these in a while and when I try, I get an error message.
Turns out my backup drive (200 gb space available) is too small for the volume in C:/.
And what is my occupied volume in c:/, you ask?
261 GB.
Yup.
Youveīread it right.
There is NO way my system occupies 261GB, only things I have there are Photoshop, a couple codecs, players, Matroska...
My Steam games are installed in another (1TB) drive.
Even the winsxs folder is "only" filled with 12gb worth of lard.
So, where is all this fat hiding and how can I fry it?
"They say that if you play the Windows CD backward you can hear satanic speech; well, thatīs nothing.
When you play it forward, it installs windows." -
On a more thorough analysis, I found this:
The C:/Users/mynameiswhatever/AppData folder is eating up 120 GB.
How can I trim it down?"They say that if you play the Windows CD backward you can hear satanic speech; well, thatīs nothing.
By browsing the AppData folder and seen what's in there that you don't need.
Also, use the Disk Cleanup tool to see what if finds that can be deleted. Delete old System Restore points. -
clean out the temp folder in appdata/local
Thanks for the repplies, guys.
System restore points was the first thing I looked into when my first disk clean sweep failed.
I think I found the perpretator:
The C:/Users/mynameiswhatever/AppData/Roaming/Adobe/Common/Media cache files folder is chugging 100+ GBs.
DO I have your clearance to kill these tribbles with extreme prejudice?
Yes, Adobe is a pig. That folder is probably full of video files you viewed with a web browser.
that folder is used by premiere pro.
Yeah, I had files there from projects I had already wrapped ages ago.
Well... not anymore.
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 15:17 -
constant updates + bloated web pages
By joecass in forum ComputerReplies: 2Last Post: 8th Dec 2011, 10:54 -
Compress hard drive to save space/Index drive for faster searching?
By orfajackson in forum ComputerReplies: 3Last Post: 31st Aug 2009, 18:55 -
Even more bloated than Windows
By ahhaa in forum ComputerReplies: 2Last Post: 20th Oct 2008, 23:04 -
Why do RM files become so bloated when converting to Flash?
By flguy in forum Video ConversionReplies: 3Last Post: 27th Jun 2008, 12:19
