    Sep 2007
    I have 75 video clips, all M2ts 1920x1080p 59fps files that I used Freemake video converter to convert to Mpeg-4 1280x720p 59.94fps and joined them together. So it plays back on my pc with a lot of stuttering? What did I do wrong? I placed both the source m2ts video files from mediainfo and the created Freemake video files here so you smart people could maybe see what I did wrong.
    Source m2ts video files:
    General
    Complete name : C:\Users\Daddy's HP Laptop\Videos\10-25-2011\10-25-2011_081146.m2ts
    Format : BDAV
    Format/Info : Blu-ray Video
    File size : 154 MiB
    Duration : 50s 769ms
    Overall bit rate : 25.4 Mbps
    Maximum Overall bit rate : 28.0 Mbps
    Video
    Menu ID : 1 (0x1)
    Format : AVC
    Format profile : High@L4.2
    Format settings, CABAC : Yes
    Format settings, ReFrames : 4 frames
    Format settings, GOP : M=3, N=30
    Codec ID : 27
    Duration : 50s 517ms
    Bit rate mode : Variable
    Bit rate : 24.1 Mbps
    Maximum bit rate : 26.0 Mbps
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate : 59.940 fps
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.194
    Stream size : 145 MiB (95%)
    Audio
    Menu ID : 1 (0x1)
    Format : AC-3
    Format/Info : Audio Coding 3
    Codec ID : 129
    Duration : 50s 560ms
    Bit rate mode : Constant
    Bit rate : 256 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Bit depth : 16 bits
    Compression mode : Lossy
    Delay relative to video : -34ms
    Stream size : 1.54 MiB (1%)
    Text
    Menu ID : 1 (0x1)
    Format : PGS
    Codec ID : 144
    Duration : 49s 986ms
    Freemake Video files:
    General
    Complete name : C:\Users\Daddy's HP Laptop\Videos\10-25-2011_081146.mp4
    Format : MPEG-4
    Format profile : Base Media
    Codec ID : isom
    File size : 7.77 GiB
    Duration : 42mn 18s
    Overall bit rate : 26.3 Mbps
    Writing application : Lavf52.94.0
    Video
    Format : AVC
    Format profile : Baseline@L5.0
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Codec ID : avc1
    Duration : 42mn 18s
    Bit rate : 26.0 Mbps
    Width : 1 280 pixels
    Height : 720 pixels
    Frame rate mode : Constant
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.471
    Stream size : 7.72 GiB (99%)
    Writing library : x264 core 112 r1834 a51816a
    Encoding settings : cabac=0 / ref=1 / deblock=1:0:0 / analyse=0x1:0 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=1 / trellis=0 / 8x8dct=0 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=8 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=0 / weightp=0 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=abr / mbtree=1 / bitrate=26000 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.41 / aq=1:1.00
    Audio
    Format : AAC
    Format profile : LC
    Codec ID : 40
    Duration : 42mn 18s
    Bit rate : 165 Kbps
    Stream size : 50.1 MiB (1%)
    Oct 2005
    666th portal
    never mind. can't read too well today /
  3. I suspect the software hard problems reading your source file. Step through the file you created frame by frame. Are motions smooth or do you see jumps and repeated frames?
    Sep 2007
    Ok my bad. It was my PC that was causing the stuttering. Actually, it plays good. Freemake did this conversion very fast (I used 1 pass fast conversion). It is over 7 GB of video that it converted in only a few hours. I did similar conversion using Bigasoft video converter and it took about 9 hrs! And bigasoft did not join the files together. Does anyone know a software that just joins files together?
  5. I'm a MEGA Super Moderator Baldrick's Avatar
    Have you tried join with tsmuxer? First add the m2ts and then click join for the rest. Output as a new m2ts.
    Maybe it works to join with copy /b command line also(or use a gui for it like vobmerge, open the .m2ts files(select all files), make new m2ts file). If the new m2ts doesn't play correctly remux it with tsmuxer.
    Or join the mp4 files?
    Sep 2007
    Ok, so I could have joined them first with tsmuxer and then converted them. I converted them first in bigasoft. Now they are Mp4 files that I need to join.
  7. my last attempt to you and then i promise I'll shut up , you seem to go in circles to find your solution, I'd do this:
    (even if #1 did not work you still have excellent media player at your disposal to play those Vegas files of yours for #2 solution)
    #1. Check if avidemux works for you (I just joined about 10 Panasonic TM700 50p clips together)
    Join your clips in Avidemux 2.6.0 , video-copy, audio-copy, save as mpeg TS muxer, just drop them one by one or at once from explorer. After that I'd recommend to remux that TS file into MKV then with mkvmerge but even just that TS file alone seems to be fine. And then you get WDTV Live plus. http://www.ebay.com/ctg/Western-Digital-WD-TV-Live-Plus-Digital-HD-Media-Streamer-/97507552
    Or
    #2.get Vegas Movie Studio, read manual, load your clips , join clips into movie and encode to whatever you want.
