Hello, first of all I would like to apologize if something wont make sense to you or you find some mistakes in my English...its not my native language.
So, to my problem: I am making videos for youtube (lets plays, gameplays) so I record a lot. I recorded in .avi so files I got were huge (40 min = 109 gb). So I decided to try x264 codec. It was awesome...good quality and small files. Then I tried to render it (the file that I recorded with x264 codec) in Sony Vegas Pro 10. First +- 50 sec looks great, but after 50s it goes all wrong. Its hard to describe so here are some pictures:
How it should look (original and first 50 sec of rendered file): http://imageshack.us/photo/my-images/689/originalhv.jpg/
And this is how it looks like after 50s: http://imageshack.us/photo/my-images/833/afterrender.jpg/
Basically it looks like Sony Vegas cant load frames quickly enough so the images get all squarly (I dont even know if that word exists).
I dont know very much about video making, basically I learn what I actually need, so dont be mean to me, if I made some totally basic mistake.
looks more like the original capture might be bad. can you play those files without any problems? use mediainfo on the original - set it into text mode and copy/paste the results here.
but also you'd get better results using the avi files and editing/rendering them in vegas. x264 is a final output format not a good editing one.--
Original capture is good, when I open it in Kmplayer it looks great and it has no problems. I want to use x264 because of size of files...when I record multiplayer gameplay (which I will cut then) files can be 1 hour long and when they are in .avi they would be really huge (150gb).
Here is mediainfo of the original:
General
Complete name : E:\27.9. - 1.avi
Format : AVI
Format profile : OpenDML
File size : 1.90 GiB
Duration : 16mn 10s
Overall bit rate : 16.8 Mbps
Original source form/Distributed by : Video:x264vfw - H.264/MPEG-4 AVC codec Audio0:Sluchátko u sluchátek s mikrofonem (Microsoft LifeChat LX-3000 ) Audio1:Sluchátko s mikrofonem (Microsoft LifeChat LX-3000 )
Writing application : DxtoryCore ver2.0.0.119
Video
Format : x264
Codec ID : x264
Duration : 16mn 10s
Bit rate : 13.7 Mbps
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate : 30.000 fps
Bits/(Pixel*Frame) : 0.221
Stream size : 1.55 GiB (82%)
Audio #1
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : 1
Duration : 16mn 10s
Bit rate mode : Constant
Bit rate : 1 536 Kbps
Channel(s) : 2 channels
Sampling rate : 48.0 KHz
Bit depth : 16 bits
Stream size : 178 MiB (9%)
Interleave, duration : 999 ms (29.98 video frames)
Audio #2
Format : PCM
Codec ID : 1
Duration : 16mn 10s
Bit depth : 16 bits
Sony Vegas 8 Pro rendering problem
By windyangel in forum EditingReplies: 1Last Post: 16th Jul 2009, 02:00 -
Sony Vegas Pro 8 problem
By Huynhjoh in forum EditingReplies: 1Last Post: 27th May 2009, 09:10 -
By Huynhjoh in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 27th May 2009, 09:06 -
Problem with swirl video fx on sony vegas pro 8
By stealers in forum EditingReplies: 1Last Post: 30th Dec 2008, 20:27 -
sony vegas pro 8.0 problem
By tp3813 in forum EditingReplies: 0Last Post: 28th Oct 2008, 07:36
