Hi,
could anyone help? I would like some software to use a pinnicle nano290-e hdtv card in XP apart from the origonal that comes with it. I have tried the likes of GBpvr, splash lite, smartdvb, progdvb etc with varying degrees of failure!!! Any sound suggestions would be appreciated thanks in advance.
hartless
SmartDVB free ( best) http://www.smartdvb.net/smartdvb/index.html DVBdream not free ( old ver 1,4 free works on xp not on windows 7 ) http://www.dvbdream.org/ ( ok) ProgDVB free ( unstable) http://www.progdvb.com/.
Dvbviewer ( very good) not free http://www.dvbviewer.com/en/index.php
I use smartdvb and have all the others for my satellite/dvb-t card, tell me what problems did you have with it maybe i can help
EasyCap Video Capture Software - No Picture On Software Screen
By Teac23 in forum Capturing and VCRReplies: 2Last Post: 9th Nov 2009, 20:26 -
Do Samsung HDTV's have an RF antenna connector for receiving off-air HDTV?
By pianopeddler in forum DVB / IPTVReplies: 2Last Post: 6th Aug 2008, 22:43 -
Need al little help getting my new ati hdtv pci card to sense HDTV channels
By MidnightMike in forum ComputerReplies: 8Last Post: 23rd Jul 2008, 03:12 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45 -
Best simple software for HDTV camera footage to H264 PS3 format
By lneves in forum Video ConversionReplies: 34Last Post: 27th Jan 2008, 15:13
