Results 1 to 18 of 18
    Aug 2008
    Greece
    Hi.
    I want to make the i am legent 2 in 1 mkv file that has the theatrical and the alternative ending into one and only stream but with the alternative ending NOT with the classic.
    How i can do that with programs like mkvtoolnix or tsmuxer(Is there any program like that but with latest updates)?
    edit: This wasn't really what I thougt you wanted....
    Aug 2008
    Greece
    As i see that program DOESN'T accept mkv files at all so i can't make one mkv file with multi streams to one mkv with only one stream.
    Thanks for your time.
    Ignore that.
    Delete one video track with mkvmergegui? And save as new mkv.
    Aug 2008
    Greece
    I know how to use the mkvtoolnix if it was so easy i don't create topic for that.
    The fact is that the movie "i am legent 2 in 1" it has the same stream and the only thing is change is the last 5-10 minutes of the movie to choose which end you want the theatrical or the alternative.
    I want to make the movie mkv file with one and only stream with the alternative end NOT the theatrical.
  6. I'm a MEGA Super Moderator Baldrick's Avatar
    Can you open the mkv in mkvmergegui and give us the details what you see under the streams?
    Aug 2008
    Greece
    The info that the topic i find the mkv file has that infos about this file.
    I Am Legend 2 in 1 (2007) BluRay 1080p DTS x264 dxva-EuReKA
    General Info
    IMDB Link: http://imdb.com/title/tt0480249/
    Length: 101 / 104 minutes
    Technical Specs
    Container...........: Matroska
    Video Encoder.......: x264 (748 Jarod's patched build)
    Video Aspect Ratio..: 2.40:1 (1920x796)
    Audio Codec.........: DTS
    Audio BitRate.......: 1536 kbit/sec
    Audio Channels......: 5.1 channels
    Subtitles...........: English + Dutch
    Source..............: Blu-ray
    File Size...........: 7.94 GB (dvd9)
    DXVA compliant......: Yes
    Extra info: - Rightclick Haali-icon in taskbar
    - Select "Edition 1" for Theatrical Version
    - Select "Edition 2" for Alternate Version
    And how i can add subtitles ONLY for the end of the alternative part and all the other movie has the normal subtitle.
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    I haven't uploaded a picture....it's just a screenshot of mkvmergegui.
    Yep, upload the details from the mkv.
    Aug 2008
    Greece
    Here it is the mkvtoolnix picture you asked me.
    As i see the alternative end is split to some chapters that the basic movie doesn't have so how i can make one mkv file only with that alternative end video stream?
    Here is the chapter file i extract from the mkv file with program mkvextract2gui.
    <?xml version="1.0"?>
    <!-- <!DOCTYPE Chapters SYSTEM "matroskachapters.dtd"> -->
    <Chapters>
    <EditionEntry>
    <EditionFlagOrdered>1</EditionFlagOrdered>
    <EditionFlagHidden>0</EditionFlagHidden>
    <EditionFlagDefault>1</EditionFlagDefault>
    <EditionUID>2906622092</EditionUID>
    <ChapterAtom>
    <ChapterUID>3143058099</ChapterUID>
    <ChapterTimeStart>00:00:00.000000000</ChapterTimeStart>
    <ChapterTimeEnd>01:40:31.577000000</ChapterTimeEnd>
    <ChapterFlagHidden>0</ChapterFlagHidden>
    <ChapterFlagEnabled>1</ChapterFlagEnabled>
    <ChapterDisplay>
    <ChapterString>Theatrical</ChapterString>
    <ChapterLanguage>eng</ChapterLanguage>
    </ChapterDisplay>
    </ChapterAtom>
    </EditionEntry>
    <EditionEntry>
    <EditionFlagDefault>0</EditionFlagDefault>
    <EditionUID>2906622091</EditionUID>
    <ChapterAtom>
    <ChapterUID>3143058000</ChapterUID>
    <ChapterTimeEnd>00:35:04.022000000</ChapterTimeEnd>
    <ChapterDisplay>
    <ChapterString>Part1</ChapterString>
    </ChapterDisplay>
    </ChapterAtom>
    <ChapterAtom>
    <ChapterUID>3143058001</ChapterUID>
    <ChapterTimeStart>01:40:31.577000000</ChapterTimeStart>
    <ChapterTimeEnd>01:40:50.096000000</ChapterTimeEnd>
    <ChapterDisplay>
    <ChapterString>Extrascene1</ChapterString>
    </ChapterDisplay>
    </ChapterAtom>
    <ChapterAtom>
    <ChapterUID>3143058002</ChapterUID>
    <ChapterTimeStart>00:35:04.064000000</ChapterTimeStart>
    <ChapterTimeEnd>01:12:45.660000000</ChapterTimeEnd>
    <ChapterDisplay>
    <ChapterString>Part2</ChapterString>
    </ChapterDisplay>
    </ChapterAtom>
    <ChapterAtom>
    <ChapterUID>3143058003</ChapterUID>
    <ChapterTimeStart>01:40:50.096000000</ChapterTimeStart>
    <ChapterTimeEnd>01:41:58.456000000</ChapterTimeEnd>
    <ChapterDisplay>
    <ChapterString>Extrascene2</ChapterString>
    </ChapterDisplay>
    </ChapterAtom>
    <ChapterAtom>
    <ChapterUID>3143058004</ChapterUID>
    <ChapterTimeStart>01:12:45.720000000</ChapterTimeStart>
    <ChapterTimeEnd>01:27:27.459000000</ChapterTimeEnd>
    <ChapterDisplay>
    <ChapterString>Part3</ChapterString>
    </ChapterDisplay>
    </ChapterAtom>
    <ChapterAtom>
    <ChapterUID>3143058005</ChapterUID>
    <ChapterTimeStart>01:41:58.456000000</ChapterTimeStart>
    <ChapterTimeEnd>01:48:18.878000000</ChapterTimeEnd>
    <ChapterDisplay>
    <ChapterString>Altend</ChapterString>
    </ChapterDisplay>
    </ChapterAtom>
    <ChapterAtom>
    <ChapterUID>3143058006</ChapterUID>
    <ChapterTimeStart>01:31:44.758000000</ChapterTimeStart>
    <ChapterDisplay>
    <ChapterString>Credits</ChapterString>
    </ChapterDisplay>
    </ChapterAtom>
    </EditionEntry>
    </Chapters>
  10. I'm a MEGA Super Moderator Baldrick's Avatar
    YOu must probably cut it manually as it just contains chapters points to the different endings. Or RERIP from your original blu-ray.
    Aug 2008
    Greece
    So based on that chapter file i make extract i can extract only the alternative end of the movie and then simple add it to the movie?
  12. You have to rip it from BD as a whole, both movie versions, theatrical and alternative version and make two MKV's for either version. It seems that you cannot play something like mkv chapter playlist or you cannot set a condition within movie to ask viewer how to proceed with further playback.
    The only thing that would make some tolerable sense and make it somehow interactive to choose ending would be to have three parts for that movie on hardisk in right order - beginning, theatrical ending, alternative ending. You'd have to press play with remote control to play files in folder subsequently (not enter) where those two endings have a force caption at the beginning that right now it is theatrical version played (or alternative ...) so if you do not wish to proceed you just press next on remote control and it will start to play alternative ending.
  13. I just google manual for mkv, I got this: http://www.bunkus.org/videotools/mkvtoolnix/doc/mkvmerge-gui.html#global_title
    so there might be a chance to link those segments somehow together, you might make it work , meaning matroska would proceed to play next file automatically
    Oct 2011
    Turkey
    d-zon3 has tell this method.but its so long so hard. here is the link ,but its turkish http://divxm.com/xin1-mkv-encode-yapimi-rehberi-d-z0n3-2in1-3in1-sunum-hazirlama-yonte...i-t349763.html
  15. nice, so it might be possible, matroska has something like "editions" so there IS actualy something like playlist of chapters
    http://mod16.org/hurfdurf/?p=8
    Aug 2008
    Greece
    Yes it did the chapters but HOW i can simply make a new mkv file with ONLY the alternative end and audio just a full movie NOT the theatrical end that this mkv has inside by default.
  17. I'm a MEGA Super Moderator Baldrick's Avatar
    You have to manually cut it out the theatrical ending then. You can cut with mkvmergegui, but it has no preview... Maybe avidemux. And then remove the linked chapters.
  18. Member
    Aug 2008
    Greece
    If i do it manually then the end it is a complete differrent fps by other movie with result the subtitle don't fit at the end of the movie so this is useless...
