  1. I have a 320 x 480 video that I want to make Bluray compliant at 720 x 480. This is what I use to upscale it:
    turnleft().nnedi3(dh=true).turnright()
    Should I denoise before or after I upscale?
  2. Banned
    New York, US
    Before.
  3. I'm using McTemporalDenoise and QTGMC. Should I use them both before upscaling or just McTemporalDenoise? Is this OK?
    setmtmode(5,9)
    Mpeg2Source("J:\2 = New\z = Encode\Raw January 12 1998.d2v", CPU=6)
    setmtmode(2,0)
    McTemporalDenoise(settings="medium", interlaced=true) # Sharpening strength is 150
    AssumeTFF() # or AssumeBFF() depending on the source
    QTGMC(Preset="Super Fast") # Removes interlacing artefacts. Strangely this is faster than Ultra Fast
    SeparateFields()
    SelectEvery(4,0,3)
    Weave()
    Tweak(Bright=10, Sat=1.0, Cont=0.8, Hue=0.0, Coring=False)
    Crop(10,0,-8,0)
    AddBorders(18,0,16,0, $000000)
    Feb 2008
    Deinterlace with QTGMC before the upscale.
    If you were doing a spatial denoise, deinterlacing would need to go before the denoise filter.
  5. Member 2Bdecided's Avatar
    Nov 2007
    deinterlace, denoise, upscale
    or
    deinterlace, upscale, denoise
    or
    deinterlace, denoise, upscale, denoise
    depending on the qualities of the noise and upscaler.
    With QTGMC and nnedi3, beware of plastic/chiselled looking video on the output. I usually put up with the plastic look, but others may prefer another approach. e.g. a simple horizontal resize with maybe a very gentle interlaced denoise (or bob/denoise/de-interlace denoise) will sometimes look better (the output will be interlaced).
    Cheers,
    David.
