  1. Ok I can convert things and burn etc, but what i am seeing is the video is really jerky, audio is in sync and everything but the video just doesn't seem right, any suggestions? thanks I have been using TMPG for converting using ntsc film, and then doing ntsc 4/3 525 lines.
  2. Need more details... System.. ripping, converting etc....
  3. just downloaded movies that play fine on PC then when I go to convert them using tmg, that parts fine, I then use nero to burn selecting vcd. The audio is synced fine but the video is really jerky, Iam I converting these wrong? Any help?
  4. Banned
    Jun 2001
    UK
    When you convert using TMPGEnc (And a VCD template???) you say your mpeg is fine ?
    But then Nero makes it bad ? Is Nero doing any conversion because your Mpeg is not fully VCD complaint ?
    Nero will add what you have already done without conversion If your mpeg is fully VCD complaint.
  5. i think I figured it out, I was doing ntsc film, 23 fps, and should be doing ntsc video, 29 fps.
  6. OK looks like I still have the problem when I use the template, its almost like there is tracers when there is movement. Any suggestions?
  7. Banned
    Jun 2001
    UK
    check the original AVI for problems, see some of my other posts.
