Ok guys, here goes...
I've got a 25 fps PAL avi that I've taken and encoded the video only in tmpge with a 23.97 fps with 3:2 pulldown on playback, not changing the framerate on the advanced tab. My resulting m2v NTSC film file is about 5 mins longer than the original PAL avi, which I understand because I have slowed down the movie. Here's where I'm stuck. I took the original PAL avi and converted the audio to a WAV file in Vdub. Stuck that in BeSweet and changed the framerate in the OTA from 1001 to 960 and made an mp2 with that. Now that MP2 is about 5 minutes shorter than the original avi file, so when I muxed the m2v and the mp2 together, hence, out of sync. I followed Truman's "framerate conversion" guide that you can find in the forums and under the "how to's" under convert. Anybody know where I went wrong? Any ideas or thoughts much appreciated. Thanks.
Results 1 to 1 of 1
PAL converted from NTSC source - Ghosting and interlacing
By OngekibouRekka in forum Video ConversionReplies: 7Last Post: 3rd Dec 2011, 13:20 -
when Pal dvd has correct Ntsc audio (Pal>Ntsc conver)
By spiritgumm in forum Video ConversionReplies: 15Last Post: 13th Oct 2011, 13:57 -
random subtitles missing after remuxing converted PAL-to-Ntsc
By spiritgumm in forum SubtitleReplies: 5Last Post: 19th Jan 2009, 12:56 -
Fix ghost effect in a bad ntsc to pal converted original DVD
By Talayero in forum Video ConversionReplies: 8Last Post: 16th Jul 2007, 06:40 -
29.976 to 25fps (removing pulldown from a NTSC converted PAL film transfer)
By ecc in forum Video ConversionReplies: 25Last Post: 15th Jul 2007, 23:31
