Sometimes when I capture using mpeg2 I get a time stamp issue and thankfully most times Womble Mpeg Video Wizard can do an mbs scan and detect where the problem lies. Then I can edit the files after it has performed that scan and has generated the files that can be worked on.
Well I have ran across a problem this morning where my AVCHD file which I got from my Hauppauge HD PVR. Looking back I probably shouldn't of been doing some encoding last night with Vidcoder the same time I was capturing video. Well anyway the trial version I am using of Tmgenc Smart Render 4 indicates the file is only 2 hours and 24 minutes and media info says the same. When I shut the capture down this morning it was 15 hours. I have dropped the file into Avidemux and it is indexing it. AviDemux is registering the same time code.
I think I will delete the file and learn the lesson of putting encodes off until the capturing is completed and not let it go for 15 hours capturing. I am curious though if there would of been some way of editing a corrupted AVCHD file.
Thanks in advance for any advice or thought on this issue.
Results 1 to 1 of 1
vob file has wrong length?
By Brainbanana in forum Video ConversionReplies: 16Last Post: 1st Mar 2012, 14:52 -
Wrong m2v file length with SmartRipper
By kenj in forum DVD RippingReplies: 9Last Post: 11th Jul 2010, 18:44 -
Authoring Works reports wrong file length
By colt4523 in forum Video ConversionReplies: 1Last Post: 31st Jan 2010, 12:06 -
AVCHD PAFF Deinterlace / Video time length problem
By tat2jr1 in forum Video ConversionReplies: 4Last Post: 24th Jul 2009, 03:58 -
Vob File Length seems all wrong
By AlexHaden in forum Newbie / General discussionsReplies: 4Last Post: 13th Jul 2008, 19:34
