I have projector and LCD TV connected via passive HDMI splitter to HDMI output of Sony laptop with Radeon 5650. They both worked well at the same time on 1920*1080 until last Win7 updates.
Now I can't use them on 1920*1080 - TV works fine, but projector has horrible distorted colors to green side even if I turn off TV. Once I switch resolution to 1680*1050 everything work(separately or together).
This situation appears on Win8 as well. Using fresh installed Win7 with driver ver 12.10 I have them work properly. But after Win7 makes updates I have a pain switching down resolution if I want to see something on projector.
I can't determine exactly which update makes this.
Does somebody have same problem?
Reinstall Win7 and turn off updates will solve the problem, but these updates should be turned off for forever, that's not a best idea. Moreover I can't use freshly bought Win8 because of that.
Walked through Catalyst CC and can't find this option.
Should I use any other utility?
HDMI splitter
By levl in forum Newbie / General discussionsReplies: 12Last Post: 28th Jun 2014, 15:30 -
2 x 1 HDMI splitter
By Novel8 in forum Newbie / General discussionsReplies: 3Last Post: 14th May 2012, 09:04 -
SOS Win7 Update hangfire- #8 never completes
By ahhaa in forum ComputerReplies: 3Last Post: 17th Feb 2012, 01:48 -
Is there an HDMI to RCA audio splitter cable for older 1.0 HDMI tv's?
By Lord Stinkfoot in forum DVD & Blu-ray PlayersReplies: 22Last Post: 10th May 2011, 17:33 -
HDMI Problem on AWA 32" LCD
By videotim in forum DVB / IPTVReplies: 7Last Post: 5th Nov 2009, 20:26
