Using Any Video Converter, I converted one of my 1920x1080p 59fps video clips to 1280x720p 60fps and I noticed as the video was playing, the Mbps is significantly LOWER with the 720p converted video. With the 1080p the Mbps averaged between 20-29mbps while the 720p clip averaged between 2.8-5.5 Mbps. What does that mean?
James
720p requires less bitrate than 1080p. If you're happy with the quality of the 720p video don't worry about it. If your not happy, use a higher bitrate.
not happy with quality. should i use constant or variable bit rate?
Constant quality or VBR question does not solve this, question is what bitrate is enough for my video.You experiment or just use encoders with constant quality settings.
Some encoders use constant quality mode, quality is controlled automatically, bit rate is generated to keep your demanded quality (set by CRF or quantizer). Not sure about your software.
There is another problem, you need to have it encoded within BD specifications, I thing you want to author your video for BD, is it this case?
edit, I can see, you are making those BD's that are: "good for my player and I do not care about other players " , so you might be all right ....Last edited by _Al_; 24th Nov 2012 at 16:28.
Well after determining what bit factor will work, I would put it into Multiavchd and author it to BD-R. Would that work?
Are there any media players that play 1080p 59fps video perfectly?
By jbitakis in forum Media Center PC / MediaCentersReplies: 7Last Post: 18th Nov 2012, 11:55 -
What is better video: 1080p 29fps or 1080i 59fps?
By jbitakis in forum Video ConversionReplies: 2Last Post: 16th Nov 2012, 22:33 -
Extract DTS-HD MA & 1080p to 720p
By thinredline in forum Blu-ray RippingReplies: 14Last Post: 9th Sep 2012, 17:08 -
ffmpeg: best possible quality for 720p h264(mp4), bitrate under 2 mbps
By lisx in forum Video ConversionReplies: 0Last Post: 1st Aug 2011, 14:56 -
Shrinking 1080p MKV, change to 720p or keep as 1080p?
By Phat J in forum Video ConversionReplies: 5Last Post: 28th Nov 2010, 09:35
