  1. Planning to get an Android tablet. Is it standard for tablets to support hi-def? Some do not mention. Is there a way for me to hook up a tablet to the TV? If so, what is needed?
  2. Many tablets have HDMI outputs, most are the "mini-HDMI" variety (just like regular HDMI, but smaller). A simple mini-HDMI>HDMI cable can be picked up on eBay for next to nothing.
    Mar 2011
    Nova Scotia, Canada
    Hardware connectivity shouldn't be a problem, but you may find that video made with tablet encoder presets aren't going to look very good on a large TV. A tablet may be hi def in theory but a 7-10" screen is a lot more forgiving. You'd want the same size file you'd use for your computer.
    You say sometimes they don't mention whether they support hd or not in the literature. I generally take that to mean no.
  4. Member racer-x's Avatar
    Mar 2003
    3rd Rock from the Sun
    I just ordered an asus tablet for my son. Does anyone know if it's possible to image the OS drive so I can restore it if /when he hoses it some day? I'm assuming I can do it via the usb connection, I'll check that out when it arrives........
    Mar 2011
    Nova Scotia, Canada
    Shouldn't this be a new thread?
    OS drive?
    You mean back up the ssd drive? Just do a search on backing up an android tablet.
    Solid state drives are pretty reliable. If anything in a tablet is going to get hosed it's the battery, and they're not replaceable. One of the main reasons I'd rather have a netbook myself ... but that's me.
  6. Member Cornucopia's Avatar
    Yes, you can backup the boot partition(s), but to do it fully & correctly, you will need to root your tablet. Good thing is Android tablets (which use Linux) are much less likely to be borked, compared to Win PCs.
    All recent model tablets, even my Pandigital, can do HD.
