Results 31 to 36 of 36
^^ Yeah, it could be a lot of things. Could be an issue with the device itself or just needing a time-base-corrector. Your computer sounds more than up to par for capturing SD footage, so I doubt it is the system itself.
What do you mean by "the picture gets broken up into parts"? -
We would spin wheels taking wild guesses without a sample of what you captured. We don't need a 90-minute movie (the forum wouldn't allow that big an upload anyway). A few seconds of a faulty part is all that's needed.
[QUOTE=robjv1;2201558]^^ Yeah, it could be a lot of things. Could be an issue with the device itself or just needing a time-base-corrector. Your computer sounds more than up to par for capturing SD footage, so I doubt it is the system itself.
What do you mean by "the picture gets broken up into parts"?[/QUOTE
Using my HDPVR I can capture HD from video games and tv just fine, no problems, but when capturing from VCR, some problem occurs where the pictures gets broken up into 3 or 4 parts.
Let's say you have someone sitting on a chair, what would happen is that sometime during the capture, the pcitrue gets broken up, where the leg of the chair would be on top of the persons head, and his leg would be on the right next to his body, all this is separated by a small black bar.
I also tried capturing different videos, now one of hem I captured in 720x480 and when capturing it doesn't skip or it doesn't drop frames, but on playback, it flickers or skips.
Then I tried 640x480 and the video is fine. I think 640x480 will be ok for a dvd. -
Could be your capture setup has problems resizing incoming analog video. The source output is usually 640x480 (4:3), so capturing that input at 720x480 involves a resize of sorts. I'd rather work with filters and color adjust in the display ratio anyway. On encoding, encode at DVD standard 720x480.
Convert all MiniDV tapes to computer and say good bye to those tapes
By iho in forum Video ConversionReplies: 38Last Post: 17th Dec 2013, 01:01 -
I need to transfer my miniDV and old hi8 tapes tapes to dvd
By bryanport in forum DVD & Blu-ray RecordersReplies: 9Last Post: 21st Dec 2012, 20:53 -
DVHS VCR performance with EP speed tapes and VHS-C tapes?
By NJRoadfan in forum RestorationReplies: 13Last Post: 8th Apr 2011, 21:36 -
Can VirtualDub record VHS tapes to AVI format?
By gregnovella in forum Capturing and VCRReplies: 4Last Post: 29th Apr 2009, 00:37 -
Converting old VHS-C and Hi-8 tapes to AVI files--HELP!
By molon labe in forum Newbie / General discussionsReplies: 10Last Post: 19th Dec 2008, 19:28
