Does anyone know how to DELETE a menu item (e.g. the chapter menu) and its link - I'm using TPMGEnc Authoring Works 4 version 4.1.2.49 -? Thanks
	Hi
 Do you mean the chapter and it's associated thumbnail on the chapter menu? If so, all you have to do is go into the CUT AND CHAPTER EDIT screen. On the left hand side you will see all of your chapters. In the upper right hand side of each chapter you will see an X. Just click on the X and the chapter will be deleted. The menus will automatically be updated after you delete a chapter or chapters.
 Brainiac
  How to delete a menu & create/insert a new one with Nero Vision Xtra?By snowseals in forum Authoring (DVD)Replies: 22Last Post: 27th Aug 2011, 00:03
  Question how to delete files that won't deleteBy jimdagys in forum ComputerReplies: 18Last Post: 9th Sep 2009, 14:09
  Change and delete some button in motion Menu?By p_samimi in forum Authoring (DVD)Replies: 4Last Post: 7th Sep 2009, 16:52
  Can't get text item 2 ????By lighangel in forum ffmpegX general discussionReplies: 1Last Post: 9th Jan 2008, 07:59
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
