I used a Canopus 300 to copy a one hour VHS tape to my computer resulting in a 13 gig DV-AVI file.
I then deshuck it with Virtualdub using Lagarith lossless resulting in a 40 gig Lagarith AVI file.
I plan to edit and remove about half unnecessary footage with Movie Maker, and add narration, transitions.
But, Instead of finishing with a highly compressed and lossy MP4 h.264 file, is it possible to use something like format factory and convert back to a managable maybe 6 gig DV-AVI file?
I have about 250 hours I would like to end up with a large external drive that could be used for viewing with a computer feeding a TV. Once the project is completed, I could make additonal backups from this master. Trying to kill two birds with one stone, Making an archival quality copy that is archival and viewable. Any opinions?
That sure would simplify things, I thought that I had to de-shake in a lossless format to keep quality. Any advice on getting Virtualdub deshaker to output in DV-AVI. If I dont pick a compression then i understand it outputs at something like 90gig per hour.
Also Movie Maker the latest version does not offer me the option of DV-AVI. It does offer me a custom quality option. See picture.But it will be in WMV, or Mp4 h.264.
I recommend you keep the original DV AVI as your archival copy. Only deshake the "hightlight reel" as deshaking will degrade the quality, especially with interlaced video. While deshaking with VirtualDub you can retain a tiny bit more quality with Lagarith -- but DV is really sufficient for VHS sources. You'd be very hard pressed to tell the difference between the two even looking at enlarged still frames. You can use Cedocida as the DV encoder in VirtualDub. There are others but Cedocida is the best and it's free.
By the way, you don't want a single hard drive to be your only backup. If that drive dies you'll lose your entire collection. Keep two hard drives. One off-site. Test them occasionally.
Best method for archival
By mdod in forum EditingReplies: 15Last Post: 25th Mar 2012, 08:47 -
Re-Encoding for Archival
By lexluthor5 in forum Video ConversionReplies: 35Last Post: 14th Jun 2010, 17:05 -
A couple simple questions about archival quality conversion
By eyeSpy in forum Video ConversionReplies: 4Last Post: 8th Apr 2009, 09:52 -
How to get an archival copy of XP sp3
By ahhaa in forum ComputerReplies: 9Last Post: 6th Nov 2008, 22:20 -
Gold archival quality DL media?
By Disco Makberto in forum MediaReplies: 16Last Post: 13th Apr 2008, 11:22
