I'm trying to write meta data to different audio formats in UTF-8. I've already made sure the command line is set to UTF-8 by checking the output of chcp which shows me code page 65001. I'm using windows 8.
The ffmpeg command params I'm running are these:
The result for the artist is "Burzum #äääüüüüüß" and the result for the title is "! Äüß!*". This looks like wrong encoding to me. I'm using foobar2000 to look at the tracks.PHP Code:
ffmpeg.exe -i "test-files\cd-quality-song.mp3" -metadata title="! Äüß!*" -metadata artist="Burzum #äääüüüüüß" -metadata track="11" -metadata date="2012" -metadata album="Test Album" -c:a copy -id3v2_version 3 -write_id3v1 1 -y "test-files\cd-quality-song.mp3" 2>&1
ffmpeg.exe -i "test-files\cd-quality-song.ogg" -metadata title="! Äüß!*" -metadata artist="Burzum #äääüüüüüß" -metadata track="11" -metadata date="2012" -metadata album="Test Album" -c:a copy -id3v2_version 3 -write_id3v1 1 -y "test-files\cd-quality-song.ogg" 2>&1
ffmpeg.exe -i "test-files\cd-quality-song.flac" -metadata title="! Äüß!*" -metadata artist="Burzum #äääüüüüüß" -metadata track="11" -metadata date="2012" -metadata album="Test Album" -c:a copy -id3v2_version 3 -write_id3v1 1 -y "test-files\cd-quality-song.flac" 2>&1
Another issue with that is that the flac file is ok, it keeps its original length of 3:19, the mp3 gets truncated for some reason to 0:06 and the ogg vorbis to 0:01! I have no idea why this happens.
Ffmpeg version:
My goal is to make this work on windows and linux and to use it within a php script. An acceptable alternative would be another tool that can write meta data to mp3, ogg vorbis and flac files at least via command line.ffmpeg version N-46146-g11d695d Copyright (c) 2000-2012 the FFmpeg developers
built on Oct 29 2012 18:10:27 with gcc 4.7.2 (GCC)
configuration: --enable-gpl --enable-version3 --disable-pthreads --enable-runtime-cpudetect --enable-avisynth --enable
-bzlib --enable-frei0r --enable-libass --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libfreetype --enab
le-libgsm --enable-libmp3lame --enable-libnut --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libschroed
inger --enable-libspeex --enable-libtheora --enable-libutvideo --enable-libvo-aacenc --enable-libvo-amrwbenc --enable-li
bvorbis --enable-libvpx --enable-libx264 --enable-libxavs --enable-libxvid --enable-zlib
Results 1 to 1 of 1
hacking about with broadcast video and meta data
By transcodeJux in forum Video ConversionReplies: 0Last Post: 31st Jan 2012, 11:05 -
how to extract meta data from a DVD?
By Toastie in forum Authoring (DVD)Replies: 5Last Post: 10th Aug 2011, 23:12 -
mp4 and created/encoded date meta data field?
By wessond in forum Video ConversionReplies: 2Last Post: 12th Jul 2010, 21:33 -
Custom Blu-ray meta data
By ni9ht_5ta1k3r in forum Blu-ray RippingReplies: 1Last Post: 28th Jun 2009, 17:40 -
Best way to create a 'correct' FLV's with meta data in?
By OM2 in forum Newbie / General discussionsReplies: 0Last Post: 29th Mar 2008, 13:43
