Hello there! I have an issue and i would like your help..
I recently changed windows from xp to 7 (64bit) and the same time changed studio 12 to 15. When i used xp+12 i had no problem playing my creations on the xbox360. Now with 7+15 the xbox360 does play the dvd, but the menu won't work (I mean you can''t choose sth from the menu, it freezes).. The DVD plays on the PC, i haven't checked it yet to see if it plays on a DVD player too.. Any idea why this is happening? I have been so confused.. I don't know what else to do! Nothing seems to make the DVD work. Could different settings solve this problem and if so what settings should i have? I even switched back to Pinnacle Studio 12, which I knew worked just fine (at least with windows xp) and now 12 won't work too!!! :'(So i figure it has to do with Windows 7! Are there any drivers or fixes or patches i should install in order to make the program work correctly with Windows 7 when creating DVD??
Desperately waiting for a solution....![]()
Pinnacle studio 14 problem with DVD export
By Alternator in forum Authoring (DVD)Replies: 1Last Post: 24th Feb 2010, 21:22 -
Pinnacle Studio: Pan and Zoom/Rendering Problem
By ashleyvideogirl in forum EditingReplies: 0Last Post: 18th Jan 2009, 03:30 -
Pinnacle Studio 11 - Problem with cropping video
By mjkamish in forum Newbie / General discussionsReplies: 2Last Post: 28th Dec 2008, 16:51 -
sound problem using PINNACLE Studio MovieBoard Ultimate S12 PCI
By Gswiss in forum Capturing and VCRReplies: 2Last Post: 12th Dec 2008, 14:11 -
Trying to edit avi in Pinnacle Studio: PROBLEM!
By L3Wi5 in forum Newbie / General discussionsReplies: 5Last Post: 25th Sep 2008, 12:09
