I have an AVI file and I want to compress it to MP4 format (progressive).
I have used Sony Vegas, the 6Mb maximum setting and it does an OK job but would like to explore other programs.
Can anyone recommend any software that would do the best job?
(I have Adobe Premiere Cs3 in case you can think of a plug in)
One of the delivery options is a "video frame" that takes an SD card for example...
MP4 is just a container but I guess you want mp4 with h264 video.
I would try a x264 encoder frontend like handbrake, vidcoder, tx264. -
Also coming along is TEncoder. It was just updated to 3.0. It has a choice of MenCoder or FFMpeg video encoders. It's multi-threaded and optimized for batch. Very handy also for muxing to another container while only encoding audio. The default is one pass mode. But it has an option to enable 2 pass. Currently it can only hard sub the video using MenCoder. But I believe the author is working on .avs script input to enable FFMPeg to perform more tasks.
http://milesaheadsoftware.org/
Fully enabled freeware for Windows PCs.
Whats the best format for good video quality with reasonable file size
By hasanali00 in forum ffmpegX general discussionReplies: 2Last Post: 20th Feb 2010, 21:29 -
Converting from Flash .flv format to iPod Compatible .mp4 format in ffmpegX
By bananasontoast in forum ffmpegX general discussionReplies: 1Last Post: 3rd Jan 2009, 09:15 -
multiplexing two files ? whats the best program
By just in forum Newbie / General discussionsReplies: 3Last Post: 22nd Oct 2008, 11:47 -
Good program for Compressing MJPG Video?
By riomarble in forum Newbie / General discussionsReplies: 3Last Post: 6th Jul 2008, 01:41 -
best format/codec for compressing an mpg???
By cduval04 in forum Newbie / General discussionsReplies: 1Last Post: 28th Dec 2007, 19:31
