Hello,
i have the following problem. my tv-harddisk-recorder (kathrein 923) saves files in .ts format (with h264 codec). But as you can imagine, are there sometimes problems in the connection over satellite when it saves the file. (so the file has some picture or audio missings)
So here is the problem. I want to decode my .ts files to put in on DVD. But the.ts files seem to be buggy from the recorder.
So i did the way over terminal with avconv.
1. avconv -ss 00:34:08 -i file.ts -target pal-dvd -target pal-dvd -t 1:15:00 -map 0:0 -map 0:1 -acodec copy file.vob
So, i am doing h264 to mpeg2 stream and the audio is an mp2 192kbit stream which i copy
Alternatives are, to use the ac3 stream but i tested a lot of constellations.
When i did this and use a dvdautorig software (dvdstyler, devede, dvdauthor gui) the software cancels with
ERR: Cannot infer pts for VOBU if there is no audio or video and it is the
ERR: first VOBU.
2. The problem seems to be the buggy fle. Because when i demux the video to mpeg2 and the audio seperate mp2 and put it then in the tool (which it puzts together again), i get no errors.
The problem here is, that the video to audio is not synchron
So when i am doing the first, the file sounds good and synchron, but i can not build an dvd.
Doing the second, i got the dvd but not synchron.
Can you give me an advice what i should or could do, to solve the problem.
If you need more information, please say it to me. (i didnt want to load every debug info in my first post)
Thanks in advance
Marcus
hello again, just got the time to pick up everything, so here are the different 2 ways.
The First which is not working but the file is synchron, and the second which is working but is not synchron:
---> So first way, just doing conversion of the file to pal-dvd
C:\Users\htpzc\Videos>C:\Users\htpzc\Downloads\lib av-win64-20121110\libav-win64-20121110\usr\bin\avconv.exe -i deichkin.ts -t 00:01:00 -target pal-dvd outfile1.vob
avconv version v9_beta2-198-g4b60fac, Copyright (c) 2000-2012 the Libav developers
built on Nov 10 2012 08:44:17 with gcc 4.5.3 (Gentoo 4.5.3-r1 p1.0, pie-0.4.5)
[h264 @ 00000000017566C0] non-existing PPS referenced
[h264 @ 00000000017566C0] non-existing PPS 0 referenced
[h264 @ 00000000017566C0] decode_slice_header error
[h264 @ 00000000017566C0] no frame!
[NULL @ 00000000017585A0] start time is not set in estimate_timings_from_pts
[NULL @ 000000000175A4A0] start time is not set in estimate_timings_from_pts
[mpegts @ 0000000001707FE0] PES packet size mismatch
Last message repeated 3 times
Guessed Channel Layout for Input Stream #0.1 : stereo
Guessed Channel Layout for Input Stream #0.2 : stereo
Input #0, mpegts, from 'deichkin.ts':
Duration: 02:18:48.27, start: 66086.736078, bitrate: 10158 kb/s
Program 28306
Program 28307
Program 28308
Program 28309
Program 28310
Program 28311
Program 28325
Stream #0.0[0x157d]: Video: h264 (High), yuv420p, 1280x720 [PAR 1:1 DAR 16:9], 50 fps, 50 tbr, 90k tbn, 100 tbc
Stream #0.1[0x157e](deu): Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.2[0x157f](mis): Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
Stream #0.3[0x1580](deu): Subtitle: [6][0][0][0] / 0x0006
Stream #0.4[0x1582](deu): Audio: ac3, 48000 Hz, stereo, s16, 448 kb/s
Stream #0.5[0x87b]: Data: [11][0][0][0] / 0x000B
Stream #0.6[0x942]: Data: [5][0][0][0] / 0x0005
Program 28326
Program 28327
Program 28328
Program 28329
Program 28330
Program 28331
Program 28385
Program 28394
Program 28395
Program 28396
Output #0, dvd, to 'outfile1.vob':
Metadata:
encoder : Lavf54.19.0
Stream #0.0: Video: mpeg2video, yuv420p, 720x576 [PAR 64:45 DAR 16:9], q=2-31, 6000 kb/s, 90k tbn, 25 tbc
Stream #0.1(deu): Audio: ac3, 48000 Hz, stereo, fltp, 448 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (h264 -> mpeg2video)
Stream #0:1 -> #0:1 (mp2 -> ac3)
Press ctrl-c to stop encoding
[mpeg2video @ 0000000001732580] rc buffer underflow
frame= 1500 fps= 93 q=2.0 Lsize= 48170kB time=60.02 bitrate=6574.8kbits/s
video:43974kB audio:3278kB global headers:0kB muxing overhead 1.943675%
---> Then starting the dvdauthor (the xml and menu is a default one and i just put in the filename of the vob)
---> The warnings are shortened!
C:\Program Files (x86)\DVDStyler\bin>dvdauthor -o "C:\Users\htpzc\AppData\Local\Temp\dvd-out" -x "C:\Users\htpzc\AppData\Local\Temp\dvd-tmp\dvdauthor.xml"
DVDAuthor::dvdauthor, version 0.7.0.
Build options: gnugetopt iconv freetype fribidi fontconfig
Send bug reports to <dvdauthor-users@lists.sourceforge.net>
INFO: default video format is PAL
INFO: Converting filenames to cp1252
INFO: dvdauthor creating VTS
STAT: Picking VTS 01
STAT: Processing C:\Users\htpzc\AppData\Local\Temp\dvd-tmp\menu1-0.mpg...
INFO: Video pts = 0.500 .. 1.020
INFO: Audio[0] pts = 0.500 .. 0.980
INFO: Audio[32] pts = 0.500 .. 0.500
INFO: Audio[33] pts = 0.500 .. 0.500
STAT: VOBU 2 at 0MB, 1 PGCs
CHAPTERS: VTS[1/1] 0.000
INFO: Generating VTSM with the following video attributes:
INFO: MPEG version: mpeg2
INFO: TV standard: pal
INFO: Aspect ratio: 16:9
INFO: Resolution: 720x576
INFO: Audio ch 0 format: ac3/2ch, 48khz drc, 'de'
STAT: Processing C:\Users\htpzc\Videos\outfile1.vob...
WARN: Discontinuity of 2 in audio channel 0; please remultiplex input.
WARN: Previous sector: 1.012 - 1.044
WARN: Current sector: 1.044 - 1.076
WARN: Audio pts for channel 0 moves backwards by 2; please remultiplex input.
WARN: Previous sector: 2.004 - 2.036
WARN: Current sector: 2.036 - 2.068
WARN: Previous sector: 3.508 - 3.540
WARN: Current sector: 3.540 - 3.572
WARN: Previous sector: 4.596 - 4.628
WARN: Current sector: 4.628 - 4.660
WARN: Previous sector: 59.348 - 59.380
WARN: Current sector: 59.380 - 59.412
WARN: Previous sector: 60.212 - 60.244
WARN: Current sector: 60.244 - 60.276
ERR: first VOBU.
---> You see, the audio seems to be not fine, but there only warnings. The Error is at the end
---> NOT WORKING
---> 2. Doing it the demux way
---> First the video (i shortened the output, so only the ouput message)
C:\Users\htpzc\Downloads\libav-win64-20121110\libav-win64-20121110\usr\bin\avconv.exe -i deichkin.ts -t 00:01:00 -target pal-dvd -map 0:0 outfile2.mpeg
Output #0, dvd, to 'outfile2.mpeg':
Metadata:
Stream mapping:
[mpeg2video @ 000000000412CAE0] rc buffer underflow
frame= 1500 fps=104 q=2.0 Lsize= 44836kB time=60.72 bitrate=6049.0kbits/s
video:43974kB audio:0kB global headers:0kB muxing overhead 1.960636%
---> Then the audio (i shortened the output, so only the ouput message)
C:\Users\htpzc\Downloads\libav-win64-20121110\libav-win64-20121110\usr\bin\avconv.exe -i deichkin.ts -t 00:01:00 -map 0:1 -acodec copy outfile3.mp2
Output #0, mp2, to 'outfile3.mp2':
Metadata:
Stream #0.0(deu): Audio: mp2, 48000 Hz, stereo, 192 kb/s
Stream mapping:
Stream #0:1 -> #0:0 (copy)
size= 1405kB time=60.02 bitrate= 191.7kbits/s
video:0kB audio:1405kB global headers:0kB muxing overhead 0.000000%
---> Then putting them together in our vob file
C:\Users\htpzc\Videos>C:\Users\htpzc\Downloads\lib av-win64-20121110\libav-win64-20121110\usr\bin\avconv.exe -i outfile2.mpeg -i outfile3.mp2 -target pal-dvd outfile4.vob
[mpeg @ 000000000161FA80] max_analyze_duration reached
Input #0, mpeg, from 'outfile2.mpeg':
Duration: 00:00:59.96, start: 1.760000, bitrate: 6125 kb/s
Stream #0.0[0x1e0]: Video: mpeg2video (Main), yuv420p, 720x576 [PAR 64:45 DAR 16:9], 9000 kb/s, 25 fps, 25 tbr, 90k tbn, 50 tbc
[mp3 @ 000000000166D0E0] max_analyze_duration reached
[mp3 @ 000000000166D0E0] Estimating duration from bitrate, this may be inaccurate
Guessed Channel Layout for Input Stream #1.0 : stereo
Input #1, mp3, from 'outfile3.mp2':
Duration: 00:00:59.92, start: 0.000000, bitrate: 192 kb/s
Stream #1.0: Audio: mp2, 48000 Hz, stereo, s16, 192 kb/s
Output #0, dvd, to 'outfile4.vob':
Metadata:
Stream #0.1: Audio: ac3, 48000 Hz, stereo, fltp, 448 kb/s
Stream mapping:
Stream #0:0 -> #0:0 (mpeg2video -> mpeg2video)
Stream #1:0 -> #0:1 (mp2 -> ac3)
[mpeg2video @ 00000000040975A0] rc buffer underflow
frame= 1500 fps=287 q=2.0 Lsize= 47586kB time=59.93 bitrate=6504.6kbits/s
video:43397kB audio:3278kB global headers:0kB muxing overhead 1.952763%
---> And the last step -- the authoring with the new file
dvdauthor -o "C:\Users\htpzc\AppData\Local\Temp\dvd-out" -x "C:\Users\htpzc\AppData\Local\Temp\dvd-tmp\dvdauthor2.xml"
STAT: Processing C:\Users\htpzc\Videos\outfile4.vob...
STAT: VOBU 96 at 44MB, 1 PGCs
INFO: Video pts = 0.540 .. 60.540
INFO: Audio[0] pts = 0.534 .. 60.470
STAT: VOBU 100 at 46MB, 1 PGCs
INFO: Generating VTS with the following video attributes:
STAT: fixed 2 VOBUs
STAT: fixed 100 VOBUs
INFO: dvdauthor creating table of contents
INFO: Scanning C:\Users\htpzc\AppData\Local\Temp\dvd-out/VIDEO_TS/VTS_01_0.IFO
INFO: Creating menu for TOC
STAT: Processing C:\Program Files (x86)\DVDStyler\data\empty_pal_ac3.mpg...
WARN: unknown mpeg2 aspect ratio 1
INFO: Video pts = 0.184 .. 6.184
INFO: Audio[0] pts = 0.184 .. 6.200
STAT: VOBU 10 at 0MB, 1 PGCs
INFO: Generating VMGM with the following video attributes:
STAT: fixed 10 VOBUs
Hopefully you can help me how i can fix that.
Thank you
Marcus -
Hi,
Try running your .ts through MPEG2Repair before trying to burn to DVD. If that doesn't work, try HDTVtoMPEG2, then use the output file to burn the DVD.
Hope this helps. -
hello again,
so, i tested the tools which you said.
mpeg2repair and hdtvtompeg2 did not work with the file.
videoredo did the job good, fixed it and after that did a dvd conform file.
but i wanted to know what the problem is. so i decided do install a linux on my system and work with the original libraries.
and look, it worked. so i did a few tests and saw that the codec which you get for windows is not working fine with the files.
So my result is: videoredo is a good tool (but it is commercial and realy expensive)
Do it under linux and you get what you want
Thank you for your help.
You can close the thread or mark it as solved
Encore Timeline Problem
By errsousa in forum Authoring (DVD)Replies: 0Last Post: 19th Jun 2012, 12:04 -
HDV timeline footage to SD (16:9 or 4:3?) NTSC dvd spec MPEG-2 file
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 19Last Post: 25th Mar 2011, 06:10 -
DVD Maestro - Timeline longer than the actual video file
By alfini in forum Authoring (DVD)Replies: 5Last Post: 15th Nov 2010, 15:49 -
Subtitle file does not match with movies timeline
By dilanalex in forum SubtitleReplies: 2Last Post: 24th Mar 2009, 23:30 -
GUI for dvdAuthoring command for no subtitles
By michcio in forum Authoring (DVD)Replies: 10Last Post: 18th Jul 2008, 10:13
