Hi, total noob at digitizing tapes, but I'm having a problem and hoping someone can help me out.
I'm using MacOS, and using a Sony J-30SDI deck to capture Digibeta PAL tapes through an SDI cable to go through Blackmagic Media Express. I've noticed that channels 1 & 2 have a german overlay over english, with channels 3 & 4 outputting only english. However, no matter what channels I select for audio monitoring, be it only 3 & 4 or only 3 OR 4, the digitil file that blackmagic records is always coming out with a german overlay. Can anyone help me with some insight into this? Thanks!
DO NOT try setting via "audio monitoring". You should go into the setup menu and look for "Output Mode" (item 026), and do a pass with L=Ch1,R=Ch2 and then do a second pass with L=Ch3,R=Ch4. It's all there in Chapter 2, page 3 of your manual.
BTW, if you are a noob, WHY are you starting off with DigiBeta?
Demultiplexing of 4 video channels and 2 audio channels.
By jays_jays30 in forum Video ConversionReplies: 1Last Post: 9th Jul 2012, 09:29 -
A Question For A Projectionist. (MC to HCCAM or DigiBeta)
By Sullah in forum Newbie / General discussionsReplies: 17Last Post: 14th Feb 2012, 12:43 -
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 15:28 -
DVD with two audio channels
By Anurag in forum DVD RippingReplies: 6Last Post: 20th Apr 2009, 00:15 -
Digibeta Deck as source input for FFmpegX
By reelrootsryan in forum ffmpegX general discussionReplies: 0Last Post: 18th Nov 2008, 16:48
