My capture card has two outputs to tv. One is a single rca composite and the second is s video. The problem is that the tv I have to use has none of those inputs. The only input for this tv is the coaxial cable that comes in from the wall. Do they make any adapters or anything that would work for me? Thanks very much.
Catman
Well you can do a couple of things here ,
Buy a new TV with S-viedo which is the best out of your chices , or run the RCA jacks through a VCR . See take the Viedo RCA and Auido RCA and plug them into the back of the VCR , then from the VCR take a coax to your TV.
Bada Bing Bada Boom :D -
There's another thing you can do - buy an RF modulator box, which converts composite video to coax cable:
http://www.bestbuy.com/detail.asp?e=11027143&m=1&cat=784&scat=811As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
What cable to output to a TV?
By Victor Hen in forum Newbie / General discussionsReplies: 5Last Post: 29th Jun 2009, 21:49 -
Output quality
By The Mighty Boosh in forum EditingReplies: 1Last Post: 15th Jun 2009, 20:11 -
Possible to output hdmi and optical output on the ps3??
By mrswla in forum DVD & Blu-ray PlayersReplies: 10Last Post: 3rd Feb 2009, 15:17 -
Output to 5.1 speakers
By LabanB in forum DVD & Blu-ray PlayersReplies: 6Last Post: 22nd Dec 2008, 12:39 -
Output to TV
By andyluong99 in forum Newbie / General discussionsReplies: 9Last Post: 18th Jun 2007, 19:05
