Information on the WinTV-HVR-2250-TV-Tuner can be found here:
http://www.hauppauge.com/site/products/data_hvr2250.html
I'm trying to record Xbox gameplay using the capture card in my computer. I'm not too sure if it's even possible, but it should be. If it is, what exactly would I need to do this?
My xbox setup is a HDMI to DVI cable that connects my xbox to a computer monitor, and for audio I also connected an A/V cable and plugged the red/white jacks into a converter to 3.5mm that connects to my headset. (I know it's not your average console setup, but it works!)
The computer that I want to connect everything to is 50 feet away (which shouldn't matter). In my experience, the A/V feature of this capture card doesn't function right, and it's a common difficulty according to the internet community. Although I'd be willing to try the A/V feature, I'd rather go with another option if there is one.
I'll only settle for HD video, and I know that the card supports it. I record television to my computer in HD. So my question is: What do I need for this? What converters, cables, etc. do I need to purchase to capture xbox footage on the Hauppauge HVR 2250?
Thanks.
I happen to have an HVR-2250. The only high-definition recording possible with the HVR-2250 is capturing HDTV broadcasts using its ATSC/QAM tuner. Those are recorded as-is from the broadcast transport stream. If you want to capture game play, it has to be done with the HVR-2250's A/V inputs, which are standard definition only. If you need an HD capture device, you will have to look for something else.
WinTV-HVR-2250 TV Tuner
By Richintx in forum Capturing and VCRReplies: 18Last Post: 23rd Mar 2010, 00:36 -
WinTV-HVR-2250 Model 1213, first impressions, great card! ... [SUCCESS]
By vhelp in forum Capturing and VCRReplies: 6Last Post: 27th Jan 2010, 23:12 -
Recording straight to MPEG2 PAL Video using a Hauppauge HVR-1800
By 3_2_DVD in forum Capturing and VCRReplies: 7Last Post: 22nd Sep 2009, 12:28 -
Hauppauge HVR 2250 won't work with PCIE 2.0
By latichever in forum Capturing and VCRReplies: 1Last Post: 15th Sep 2009, 09:18 -
Hauppauge WinTV HVR-1800 Jerky unless recording
By michaeldg1 in forum DVB / IPTVReplies: 4Last Post: 6th Apr 2009, 16:10
