There have been recent posts regarding unlocking Samsung 3 d players but no instructions could I have some please
Results 1 to 9 of 9
if there even is a hack for your player it will only be for the dvd side of the player.
I would like to play NTSC discs ,although it plays NTSC blue ray it won't play standard ntsc DVDs
Your Blu Ray discs are probably not zone coded(region coded), but your DVD discs ARE region coded.
99% chance you will NOT find a hack for that player. -
Easy way to tell: rip/decrypt an NTSC dvd to ISO and then burn it. Since most decrypters automatically remove region coding, uops, etc, you will now be able to see if it is a region coding problem (with easy fix of just repeating the rip-reburn process) or is an NTSC problem. That you probably couldn't fix even with an "unlocked" player.
Note: DVDs really only support 2 systems (NTSC 29.97 and PAL 25, with film using the pulldown trick on NTSC) . BDs truly support 3 systems: Film is specifically included on its own, as 24 or 23.976. This is probably the reason you notice a difference in compatibility.
Btw, @hech54, there plenty of BDs that are region coded. -
Thanks for all your comments, I,ll put up with just playing them on another player
It depends on what you buy.
Disney almost always region locks their BD discs. They remain somewhat infamous for staggered release dates as a result. It's been known for some movies to come on BluRay up to a full year later in some BluRay regions than others, so region locking is a big deal for them. Sony is also known to region lock some releases.
Some Hollywood studios don't care so much. I have the impression that Universal doesn't care all that much about region locking.
Some of the smaller Hollywood studios region lock everything they put out. Speciality production houses like Criterion are required by their contracts to region lock either every disc they put out or close to it. They are basically only licensed for North America for their releases. The British Film Institute has similar restrictions, but for Europe.
Many foreign films don't get region locked at all. It's very unusual for a Hong Kong movie to be region locked, for example.
At least the BD regions make sense (in my opinion) and they're not as stupid as the DVD region sceme was.
How to unlock Samsung HT-D550
By Flaviagois in forum Newbie / General discussionsReplies: 3Last Post: 16th Jul 2014, 07:21 -
Samsung Smart Blu-Ray 3-D Player - Model BD-D5800 Region Unlock/Hack
By VoYD666 in forum DVD & Blu-ray PlayersReplies: 7Last Post: 24th Oct 2012, 05:49 -
Region free hack for Samsung HT-E5550W
By kohum in forum Newbie / General discussionsReplies: 2Last Post: 16th Sep 2012, 13:59 -
Unlock Samsung DVD-D360k
By Vicjerry in forum DVD & Blu-ray PlayersReplies: 0Last Post: 17th Aug 2011, 14:42 -
Unlock Samsung 1080P8 R1
By erix2 in forum DVD & Blu-ray PlayersReplies: 2Last Post: 1st Nov 2008, 07:18
