Hello...!
I have a Avermedia BT848 card, but the program of Avermedia is very poor..
and I have any questions:
=>What's the best program for ripping videos?
I´m using iuVCR, but not working very good.
and:
=>What's the best codec?
12 minutes is a slow response time?
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
hello,I have this dc30+ from miro and I use the miro capture software,work very well...I recorded yesterday my childrens painting eges,today I capture with this dc30+ card,then I save the file as .avi,then I use the Panasonic Encoder to convert to mpg,after that I open the mpg file with TMPEG and I got the mpg file ready to burn in a cd to be play as vcd in my dvd player,I did that with the vcdEasy I am very happy with the quality,even when my camera is analog,the picture is very good...
you can capture only 5 to 7 minutes with this card and with the most capture cards,,but I think that you can capture a lot longer with win2K,most capture cards and software are kinda tricky to use,but if you find the forum for your capture card I am sure you will get very good results,that what I did a while ago,now I can get my hardware and software ready in just few minutes.
I think that you should find some other users of the same card that you have,and then you can get very good tips from people who know very well that specific card..
good luck.Rigo.F
how do I install x264.exe to work AND to work with Lemings GUI?
By Krelmaneck in forum Newbie / General discussionsReplies: 1Last Post: 14th Nov 2010, 23:13 -
You want newbie? This is newbie. Watch VHS movies.
By Mighty Melvin in forum Newbie / General discussionsReplies: 14Last Post: 12th Oct 2009, 09:43 -
HELP Burn using Nero Express doent work /but NERO VISION work fine
By STAR36 in forum Authoring (DVD)Replies: 4Last Post: 28th Apr 2008, 17:11 -
How much do you work? (work = doing something you are getting paid for)
By Baldrick in forum PollsReplies: 20Last Post: 26th Nov 2007, 16:35 -
Newbie: Why doesn't it work?
By orchestr in forum ffmpegX general discussionReplies: 8Last Post: 24th May 2007, 12:30
