What is clearer, better video: 1920x1080p 29fps OR 1920x1080i 59fps?
I have to convert some 1920x1080p 59fps to either 1080p 29fps or to 1080i 59fps in order to be blu-ray compliant. So which would you do?
James
60p is the best, why you guys try to bring a mounting to Mohamed ... get something that will play that 60p
Sure you can also get 60i from 60p but why, this is only for distribution (BD specs limitations) not for home video.
To make 30p out of 60p is a problem because both need different shutter speed. -
Well AL, what will play 1080p 59fps?? Please enlighten us. The reason I am asking is right now I don't have a player that supports 60p evidently. I have a PS3. Is it the player that is the problem or the Bd-r disc?
James
Are there any media players that play 1080p 59fps video perfectly?
By jbitakis in forum Media Center PC / MediaCentersReplies: 7Last Post: 18th Nov 2012, 11:55 -
Can I record in 29fps with a camcorder that usually does 59fps?
By jbitakis in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 16th Nov 2012, 22:41 -
1080i to 1080p
By slobadaca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 6th Jan 2011, 05:38 -
Camcorder: buy 1080i or 1080p? Final Cut Express only does 1080i
By adrien23 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 13Last Post: 12th Nov 2010, 05:37 -
1080i vs. 1080p
By Shibblet in forum DVB / IPTVReplies: 31Last Post: 27th Sep 2008, 13:24
