  1. Summary:
    creating a dvd to play on TV
    Product Level 1:
    Camtasia Studio
    Product Level 2:
    Version 5.1.0
    Date Created:
    11/16/2012 05:22 PM
    Last Updated:
    11/16/2012 05:22 PM
    Status:
    Unresolved
    Problem Type:
    Technical Questions
    Trial or Registered:
    Registered User
    Maintenance Number:
    Op. System:
    Windows 7 64-bit
    Discussion Thread
    Auto-Response
    11/16/2012 05:22 PM
    The following answers might help you immediately. (Answers open in a separate window.)
    Answer Link: Making a DVD of Camtasia videos
    Answer Link: How can I use Pack and Show to create a self-running video with Camtasia Player?
    Answer Link: Capturing DVD playback with Camtasia Studio/Recorder is blank
    Answer Link: Relative links in Hotspots
    Answer Link: Saving PowerPoint videos to DVD
    Customer By Web Form (Donald Hocutt)
    11/16/2012 05:22 PM
    I have a Sony Camcorder and created a home movie. I attached the Camcorder to my computer and it downloaded the video files (MTS) and the Sony software allowed me to create a DVD. I did this and the DVD plays fine on my computer and TV. I wanted to over lay a song on the video but before I tried to use Camtasia to do that I used Camtasia creating a simple AVI file (CD option) and created a DVD. The DVD plays on my computer BUT NOT on the TV. Is Camtasia capable of creating a DVD that will play on TV ? What options or Camtasia versions do I need ?
  2. Member DB83's Avatar
    Jul 2007
    Camtasia does NOT create dvds. Read the answer1 from above again in trying to use the mentioned DVD AUTHORING software.
    Camtasia is screen capture software. Screen sizes are not dvd friendly so you have to do all sorts of manipulation to the captured image.
    You could try some different authoring sofware such as AVStoDVD and then use imgburn to transfer those files to a dvd.
    The other possibility is that your dvd-player - the one that you use for the tv - only supports one type of blank media - either -R or +R - and you used the wrong one
