Hello,
I finished working on my recording with VirtualDub and my videos have 50 FPS per second..
I need a video editing software which keep the number of frames per second.
Previous programs I tried did not do it .. They made the video to 25 FPS Which impairs the movement in my video ..
Thanks for helpers!
Thank you.
But I need something that looks easier to use ..
Such as Camtasia Studio. But not too simple like Windows Live Movie Maker -
Disables, as in "freezes"? BSOD? Skips?
Then it might be a faulty installation, or it could be an indication that your computer really isn't up to scratch for what you're trying to do. Did you look at "system requirements" and "recommended systems" when checking out those apps? They are there for a reason.
Scott -
problems like crashes with vegas are usually due to GFX driver issues
What do you mean "large videos" ? If it's something like 1080p60 lagarith, not very many systems can handle that in real time. You need a faster setup and probably more suitable intermediate . You might be running into I/O bottlenecks with uncompressed video for example
Be more specific in communicating what the problems are
Curious requirement - stop video every 5 seconds on demand
By cellishmania in forum EditingReplies: 0Last Post: 28th Feb 2012, 07:16 -
Question about which editor I should use for a specific task.
By DoctorDyna in forum EditingReplies: 6Last Post: 1st Feb 2012, 12:34 -
ISO Video editor recommendation
By coyote2 in forum EditingReplies: 4Last Post: 4th Oct 2011, 00:42 -
recommendation for TVs ( specific requests stated! )
By savvyguy in forum DVB / IPTVReplies: 52Last Post: 5th Jul 2010, 00:14 -
video editor recommendation
By chillyair in forum Newbie / General discussionsReplies: 12Last Post: 2nd Jul 2008, 18:25
