Hi,
I have a video editing program that came with my camcorder (Panasonic HD Writer AE) that is able to manipulate files from my camcorder rather well (lossless trimming and appending, rendering only the transitions). Unfortunately, it accepts only AVCHD 1080i (or 1080p) video. I have a few videos from a digital camera that use a different codec and are 720p30 that I would like to add to the project.
how can I convert this:
to this:Code:Video ID : 1 Format : JPEG Codec ID : jpeg Duration : 18s 500ms Bit rate mode : Variable Bit rate : 25.6 Mbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 30.000 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Compression mode : Lossy Bits/(Pixel*Frame) : 0.924 Stream size : 56.4 MiB (100%) Language : English Encoded date : UTC 2012-09-01 12:20:48 Tagged date : UTC 2012-09-01 12:20:48 Audio ID : 2 Format : PCM Format settings, Endianness : Little Format settings, Sign : Unsigned Codec ID : raw Duration : 18s 500ms Bit rate mode : Constant Bit rate : 64.0 Kbps Channel(s) : 1 channel Sampling rate : 8 000 Hz Bit depth : 8 bits Stream size : 145 KiB (0%) Language : English Encoded date : UTC 2012-09-01 12:20:48 Tagged date : UTC 2012-09-01 12:20:48
I'm comfortable with entering cryptic commands into ffmpeg, but this doesn't quite work (the output isn't interlaced):Code:Video ID : 4113 (0x1011) Menu ID : 1 (0x1) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.0 Format settings, CABAC : Yes Format settings, ReFrames : 4 frames Format settings, GOP : M=3, N=15 Codec ID : 27 Duration : 23s 957ms Bit rate mode : Variable Bit rate : 11.8 Mbps Maximum bit rate : 16.8 Mbps Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate : 29.970 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan order : Top Field First Bits/(Pixel*Frame) : 0.189 Stream size : 33.6 MiB (94%) Audio ID : 4352 (0x1100) Menu ID : 1 (0x1) Format : AC-3 Format/Info : Audio Coding 3 Mode extension : CM (complete main) Format settings, Endianness : Big Codec ID : 129 Duration : 24s 32ms Bit rate mode : Constant Bit rate : 256 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 48.0 KHz Bit depth : 16 bits Compression mode : Lossy Delay relative to video : -67ms Stream size : 751 KiB (2%)
Any other utilities I can try? Ideally if they'd also generate the corresponding .cont, .pmpd and .tmb filesCode:$ ./ffmpeg.exe -i camera.mov -codec:a ac3 -codec:v h264 -s 1920x1080 -vf tinterlace output.m2ts.
The description looks promising, but the default Windows version can only decode (and not encode) AVCHD. It can decode my mjpeg directly
Any other suggestions?Code:$ ./FFmbc-0.7rc7-win32/ffmbc -codecs Codecs: D..... = Decoding supported .E.... = Encoding supported ..V... = Video codec ..A... = Audio codec ..S... = Subtitle codec ...S.. = Supports draw_horiz_band ....D. = Supports direct rendering method 1 .....T = Supports weird frame truncation ------ D V D 4xm 4X Movie [...] EV h263p H.263+ / H.263-1998 / H.263 version 2 D V D h264 H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10 DEVSD huffyuv Huffyuv / HuffYUV [...] D V D mimic Mimic DEV D mjpeg MJPEG (Motion JPEG) D V D mjpegb Apple MJPEG-B [...] FFmbc version 0.7-rc7 Copyright (c) 2008-2012 Baptiste Coudurier and the FFmpeg developers
AVCHDCoder - I couldn't get it to recognize the audio tracks (and it refused to proceed further). I tried transcoding to an intermediate format, and still no luck... (maybe I just picked the wrong formats)
multiAVCHD - really nice program I'll keep in mind when I make BluRay discs, but unfortunately the discs it makes can't be imported into Panasonic HD Writer AE 4.0. It might be that Panasonic Writer recognizes only discs it made itself (to avoid editing commercial movies or something).
MPEG StreamClip - maybe I misread, but I didn't find a way to convert from mov to m2ts
Thank you for all the suggestions, but it appears that Panasonic Writer is really picky with what it accepts and short of filming my screen there is no way to get external videos in there. I will decide how badly I want this external footage and maybe switch to a different editing program.
How do I deinterlace 1080i ProRes 422 MOV files?
By Skycap in forum Newbie / General discussionsReplies: 2Last Post: 12th Nov 2012, 20:03 -
Trying to convert x264 .mov to .m2ts
By Onceler2 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 30th Sep 2012, 11:20 -
.m2ts to .mp4; H.264, 1440:1080i; Tivo and Streambaby
By OmegaTCB in forum Newbie / General discussionsReplies: 2Last Post: 17th Jul 2011, 17:33 -
Convert AVCHD Video (.m2ts).
By Oilte in forum Video ConversionReplies: 2Last Post: 16th Sep 2010, 08:56 -
M2TS to Mov?
By Benhermies in forum Newbie / General discussionsReplies: 0Last Post: 13th Sep 2009, 23:17
