I have the issue where the bottom of my video (if there are subtitles) gets reflected, causing the subtitles to be obscured. It works fine on my desktop using the same video. Anyone help? I have also tried this in multiple programs and the result is the same. Screen shot attached below:
Crap I can't edit the title, meant reflected
Same problem with other players like VLC Media player?
It's probably some subtitle filter problem. Have you installed any codec packs? or just ffdshow or vsfilter?
And you can edit your thread title, just click go advanced after you clicked on the edit button. -
Yeah I think it was a filter problem, did some re-installing and the problem was fixed. Thanks!
Sony Vegas 10, media showing crosshairs in bottom right of screen??
By damonj_3 in forum Newbie / General discussionsReplies: 11Last Post: 8th Sep 2011, 15:13 -
tv screen cuts sides and bottom of pic..
By andie22 in forum Newbie / General discussionsReplies: 7Last Post: 15th Jul 2011, 13:50 -
Question - Black bands on top and bottom of the screen. (16:9 TV)
By Rainbow1962 in forum Newbie / General discussionsReplies: 31Last Post: 16th Jul 2009, 02:45 -
What encoding to fill screen top & bottom with 4:3 on Youtube?
By brassplyer in forum Video Streaming DownloadingReplies: 12Last Post: 30th Jun 2009, 12:40 -
Zoom / Small blue box bottom right corner of screen on Philips DVP-3252
By DVP-32 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 25th Jul 2008, 15:34
