Results 1 to 22 of 22
    Oct 2011
    Turkey
    hi
    i like virtualdub deinterlance.some football videos ,ı capture from dvbs, ı use bob deinterlance algorithym and double frame rate.it is so perfect.but ı use my logo on it.vşirtualdub cannot use gif logos and it looks bad.can you advise me a video editor or any tool can deinterlance like virtualdub.ı do not wanna make 2 or more conversation.i can do like this first ı convert with virtualdub and other program ı ,with deinterlanced video, add my logo.ı wanna know if there is a one program to do all this
    Have you tried the http://neuron2.net/logo/logo.html plugin?
    Or else maybe try avisynth (script video editor, but google for logo examples scripts).
  3. Banned
    New York, US
    AVisynth has a lot of logo filters, and you're better off working in YUV anyway before going to RGB in VirtualDub. No logo filter is perfect. Spmetimes it's better to leaving the logos as-is.
    While VirtualDub's bob deinterlace is OK for a quickie view, it's way inferior to deinterlacers in Avisynth such as yadif (faster) or QTGMC (slower, but best).
    Unfortunately you have not given us enough information about these captures. How are you capturing? Is the source "dvb" or did you mean DVD? Why are you deinterlacing? What is your ultimate goal for final output? A short sample of your capture would help members give more detailed advice and show you examples of what can be done. Otherwise, there's not much anyone could add.
  4. Originally Posted by sanlyn View Post
    He's adding a logo, not removing one.
  5. i will recommend ffmpeg - you can perform at once deinterlacing (yadif), resizing (if necessary), add logo etc. then encode
    syntax for cmd can be a bit odd for a first time but anyway it works quite OK
    ffmpeg -y -i %1 -filter:v "yadif=1 [xxx]; movie=test.png [yyy]; [xxx] [yyy] overlay=W-w-16:H-h-64" -q:v 2 -codec:v mpeg2video -codec:a copy "test.mpg"
    Oct 2011
    Turkey
    thanks friends
  7. Banned
    New York, US
    Oops. Then there's always "Overlay".
    Oct 2011
    Turkey
    hi again.ı worked so hard.get so angry but finally ı make a simple way.ı made a transparent gif which is about my video resolation. 720x576.put my logo frront of channel logo,i must set location for every different channel,my transparent psd is fornt of main video.so ı have a logo added vidoe.ı use photoshop trial.but gimp is a free tool to make transparent pictures.after ı get my logo on video.i try to encode on adobe premiere.bu exported video is bad.so low quality.this evening ı will try adobe encore to encode it,do not encode with premiere.well ı hope it works fine.i searched for AVisynth but ı dont understand anything
    Oct 2011
    Turkey
    hi again in TMPGEnc Video Mastering Works 5 we can use photoshop psd file so we can make adding logo with this program or anythig.it can deinterlance so well.to night there is a football mathc turkey danmark.i try to capture it and make a totorial for anybody wants to add logo easyly
  10. If you're just using a static logo why does it have to be GIF? Convert it to a BMP for the logo, and and another BMP for the alpha mask. Then use VirtualDub's logo filter.
  11. Banned
    New York, US
    Here's an effort using some flawed football footage I had lying around. Make a logo .BMP and overlay it in Avisynth
    Hopefully your logo is nicer than mine.
    Sorry for the format of the sample. This was a quickie MPEG1 sample 352x480, no audio (60fps isn't compatible for MPEG2).
    VID=MPEGSource("C:\Path\To\videofile.avi") # <- or MPEG2Source, or whatever source
    LOGO=ImageSource("C:\Path\To\Picture.bmp")
    VID=VID.AssumeTFF().QTGMC()
    LOGO=LOGO.ConvertToYV12()
    OUT=Overlay(VID,LOGO,X=230,Y=34)     # <-X and Y are the coordinates for placement of logo bmp
    return OUT
  12. DECEASED
    Jun 2009
    Heaven
    ......(60fps isn't compatible for MPEG2).
    Not true, definitely.
    Oct 2011
    Turkey
    Here's an effort using some flawed VHS football footage I had lying around. Make a logo .BMP and overlay it in Avisynth
    Hopefully your logo is nicer than mine, and the display ratio of the logo itself is "off". Didn't have a lot of time for this.
    [Attachment 14712 - Click to enlarge]
    VID=AviSource("C:\Path\To\videofile.avi") # <- or MPEG2Source, or whatever source
    return OUT
    hi
    ı make logos like channel logo look at this
    not the best but ı do it in one minute with paint.and use photoshop to transparent it.u try tmpengc to get pure export video.channel has got mpeg2 stream with 9500Kbps.almost hdtv
    Oct 2011
    Turkey
    hi again.after a hard work finally ı could add my logo and deinterlance so well.ı use TMPGEnc Video Mastering Works for everything.ı create a little logo with paint and make it transparetn 720x576 in photoshop.720x576 is not important. my deinterlance setting is like this(deinterlance method may change for every channel.some channel may not need)
ID:	14715Click image for larger version
    Oct 2011
    Turkey
    hi again here is my exprted video.ı made 2 files each of 350 MB.ı know low but ı will send it to my friends.specially look at ball moves.
  16. Banned
    New York, US
    You're correct, I just didn't look that far down in the menu and was in a big rush.
    Oct 2011
    Turkey
    is there any one to learn how ı can add logo ı can make a toutorial
  18. Originally Posted by montevo View Post
    Not to rain on your parade, but who wants to see a video ruined by your logo? Is your ego so big you feel the need to add it to your videos? I saw your sample and to me it looks like someone took a big shit in the upper left corner.
  19. Banned
    New York, US
    Ouch
    Well, two problems. (a) There are probably easier ways to do it. (b) the logo's shape will change when the video is played 4:3 or 16:9 or whatever.
    Oct 2011
    Turkey
    manono older movies in turkey vipsas make them bluray.they made restoration.pictures are so perfect.and these movies only on tv,for now.ı capture them and uploaded most forum sites to share.and write my name in filename,not to picture.but some of the users download them and share like they made they ripped.ı just want dont erase my name in filename.and there is no one rip these broadcast.only me.ı chacked topics,checked filesize,checked everything.because of these ı decide to put a logo.ı localize my logo on channel loto.ı dont wanna disappare more picture.vipsas countinues to restoration.they make super quality.
    by the ways these channels ı have captured not scrembled,not a pay per view or anything.here is my caps
    here is the orj channel caps
  21. Originally Posted by montevo View Post
    So what? Do you really think that by defacing the video with your name it's going to stop people from stealing your work? For example, YouTube is full of videos with one person's name that someone else has taken and added to their channel. They steal my videos too (no logos, but I know my own work). If you love the good quality of those movies you share, you wouldn't purposely degrade them by adding a logo. If you insist on using a logo, add it to the movie for maybe 5 seconds and then be done with it. That way people don't have to see the nasty thing the whole time they're watching the movie
    As for all those pictures with logos, again, so what? If you don't like them, remove them. That's my point. People all around the world watch TV shows with logos plastered all over them. And they get the idea it's OK to have logos themselves. It's not OK to put logos on those movies you share. Not OK for you, not OK for the TV channels or others that do it. Of course, you can't do anything about them. In the US now it's gotten so bad that not only do you see the channel logo, not only do they promote their own upcoming shows, but some cable channels now even run real advertisements during the show. It's disgusting.
  22. Member
    Oct 2011
    Turkey
    in turkey everybody calss this "theft of labor".or we can call this we are making a name on internet.if vipsas relase blurays or dvds to stores,i do not need to capture them.there are more rip groups in turkey. they make rips they take care of pirate.like as you ı dont like logo of channel.you see this kanal 7 logo is so big.ı watched galatasaray match last night on az tv in turksat 3a.there are 3 big logos.just like spam broadcast.@manono you gave me a think.ı mail to channels to make ther logos transparent.thanks body.
