i just bought the TV Wonder VE and have toyed around with the visuals and have since obtain a very satisfactory results in that aspect. but, whenever the audio plays...it plays it like its trying to BLARE out of a tiny tiny speaker, providing me without the desired results. my vcr can out only one audio plug, is that a problem? i try to lower the Mic (cant fit plug into the line in....too tight a squeez) volume and it comes out lower, but still blaring. i set the audio to mono and it helps an inch with background audio but voices are stil VERY VERY LOUD when they should not be. i use the capture software that came with the TV Wonder VE card.
any help would be good help,
Dan
the best way is to use line in, not mic in. the inputs have different impedeance. the audio of you capture card is to hot for the mic input.
you need to find away to get into line in.
Yeah, ditch that mic-in connection; grab a short extension for your line-in if that's what it takes to get it enough clearance to plug in.
As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
Tools Needed Clean up iPhone Concert Video's Audio
By xr280xr in forum Newbie / General discussionsReplies: 5Last Post: 17th May 2011, 18:55 -
Clean uninstall of ATI AIW 9600
By justin81 in forum Capturing and VCRReplies: 3Last Post: 23rd Dec 2009, 11:41 -
recording audio using the ati tv wonder pro
By cadams8221218 in forum Capturing and VCRReplies: 4Last Post: 22nd Mar 2009, 19:12 -
.flv demux for audio clean up
By longislandgrafix in forum EditingReplies: 1Last Post: 29th Jan 2009, 11:17 -
Clean up audio on AVI file
By marybutts in forum AudioReplies: 2Last Post: 11th Jan 2008, 07:15
