Hello,
I've been trying to edit a DVD and re-author it, but so far no luck. The editing consists of removing three scenes from the dvd. What would be the best way to do this.
My goal is to keep the exact structure as it is now (so menu's chapter, trailers and whatever), just the main movie without the three scenes.
Should I first demux everything and than mux it together?
Edit: I've extracted the subs allready in a .txt file.
Thanks in advance!
DVD Remake pro.
If you want to use free tools checkout vobblanker (click on it for guides). -
Okay, well I've managed to edit the main movie the way I want it. I've also managed to edit the subtitles in such a way they are in sync with the movie again.
So now I've the following problems. First I need to convert the mpeg2 file to .vob files and mux the subtitles together with them. Then I've to update the .ifo files so everything fits nicely together again. I've allready tried this, but it didn't work. Do you know any tools and ways I can accomplish this? If needed I can upload files or pictures of how it looks like. -
How are you doing that? And how does it not work?
You can read the dvd subtitle replace guide that I made for some tips, https://forum.videohelp.com/threads/277950-How-to-add-new-subtitles-to-an-existing-DVD (method 2) -
"Edit & Re-author DVD with same structure" - WHY? Why does it need to have the SAME structure? If "similar" works, you could easily author in ANY dvd authoring app (free or pay) and probably include subs to boot.
Scott -
And how many hours did you waste doing all that? You didn't even have to demux. As Baldrick mentioned, VobBlanker can easily do what you want. He even mentioned checking the VobBlanker guides on the VobBlanker page. To make it easier for you, since apparently you don't know what to look for, I'll link to the applicable guide below:
http://download.videohelp.com/jsoto/guides/VobBlanker/prevcut/index.php -
How to re-author back to bluray from BDMV bluray structure?
By eummagic in forum Authoring (Blu-ray)Replies: 1Last Post: 1st Dec 2010, 21:14 -
DVD structure
By gbabione in forum DVD RippingReplies: 6Last Post: 19th May 2010, 22:41 -
Any free tools to author DVD structure with menu buttons?
By p23185 in forum Authoring (DVD)Replies: 1Last Post: 1st Mar 2010, 16:03 -
Possible to edit dvd mpg but preserve menu structure?
By tppytel in forum LinuxReplies: 1Last Post: 10th Dec 2009, 00:57 -
edit, splice 1920x1080 footage and author BluRay
By joviparagon in forum Newbie / General discussionsReplies: 3Last Post: 31st Jul 2008, 10:51
