When I converted a divx music video to VCD MPEG using TMPEnc 2.53 and the toolame encoder the audio is knocked out of sync slightly by a split second or so. Is there anyway I can fix this in TMPGEnc without having to go through alot of work?
Thanks!
Generally, I always load the .avi file up first in VirtualDub and extract the audio to a separate .wav. Then, in TMPGenc, I set the video source as the .avi and the audio as the .wav, and let TOOLame and TMPGenc run their course.
Since I've starting doing this, I've had no problems with sync. -
Thanks for the tip. I tried extracting the audio with virtual dub then converted the wav and avi to mpeg with TMPG ENC and I had the same sync problems. The DIVX Avi is synced correctly, I wonder what is throwing it off? Any ideas?
HEy! I have the same problem! See my post where no one cares
There has to be a way to fix this
http://forum.vcdhelp.com/viewtopic.php?t=84884 -
Sorry it's taken so long.
What are you using to multiplex the files? TMPGenc never worked too well for me, but BBMPEG seems to do the trick. -
In Virtual dub under audio select "Full processing mode"
See here for more details:
http://www.doom9.org/mpg/avi2svcd.htm
audio video sync issues after converting to mpeg with "Burn"
By wsgoogoo in forum MacReplies: 4Last Post: 9th Nov 2010, 20:02 -
Question why un-installing 1 software knocked out 3 other softwares
By jimdagys in forum ComputerReplies: 6Last Post: 25th Sep 2009, 22:50 -
Audio Sync Problems when converting MPG to Divx
By kbehel in forum Video ConversionReplies: 1Last Post: 16th Jan 2009, 22:18 -
Problem converting audio of VCD MPEG-1 to author DVDs
By Greycat in forum Video ConversionReplies: 6Last Post: 16th Jan 2008, 17:28 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 05:38
