I'm using Any DVD Converter to rip DVD. I'm looking to rip to a format that is best viewed on a widescreen LCD TV. I will also view the same files on ipad2. Is there a single format I can rip to that will allow viewing on both devices? I'm thinking MP4 or avi, but I'm struggling to get the correct aspect ratio.
TIA
I would convert using the free handbrake with the ipad preset/profile. Ripping with free dvdfab decrypter.
How are you playing the video on your tv? Does the tv have a builtin player or?
edit: And I changed your thread title. -
Sorry, but I don't think you'll find anyone here who's knowledgeable who recommends any dvd converter. Unfortunately this is the kind of thing where you do not necessarily get what you pay for. The programs baldrick suggested are the best ones you can find that don't require you to be a highly knowledgeable video geek. And they're free.
There's a simple reason your iPad profile settings don't look good on your tv. It's a much bigger screen and thus doesn't mask low quality encodes so much. There's no software that can fix that.
In fact, one of the most common problems noobs have with handbrake/vidcoder is that the default preset is for mobiles. They don't understand that they need a higher profile to get halfway decent quality on a real screen. For a bigger screen you need the high profile and 8x8 DCT just for starters. -
There are tons of guides, but there's no simple how to for the advanced encoding parameters.
Start with handbrake or vidcoder, set it to high profile, enable 8x8 DCT in the advanced settings section.
Try the handbrake constant quality mode, which is actually badly named but that's another story. Set the quality factor to 18-16. Lower numbers = higher quality and bigger files.
if you want to try the target bit rate mode, it should be at least 2300 or so for good quality. Just don't use the 1 pass mode. It's the fastest but the quality is not good. That's not handbrake's fault, it's true in general. Better quality = more time encoding, and the only way around that is to buy a faster computer.
Constant quality mode in handbrake will give you about the same quality as 2 pass target bitrate and it's much faster. But you can't predict the file size of the output very accurately.
Newbie needs help/advice on backing up
By squale247 in forum Newbie / General discussionsReplies: 7Last Post: 11th Feb 2012, 19:27 -
Conversion advice for a newbie
By darafat in forum Video ConversionReplies: 1Last Post: 20th May 2010, 02:17 -
Advice for a total Newbie
By Lawman1965 in forum Newbie / General discussionsReplies: 1Last Post: 25th May 2008, 13:24 -
Newbie looking for advice.
By mopar339 in forum DVD RippingReplies: 1Last Post: 14th Feb 2008, 02:36 -
By mopar339 in forum Newbie / General discussionsReplies: 1Last Post: 14th Feb 2008, 02:35
