Alright so I'm new to blu-ray ripping and i tried a couple programs. So far, none of them did what i want or at least I'm not sure what settings i need to enable and whatnot.
Basically, what i want to do is make a backup of an anime blu-ray disc. How i want to do it is rip each episode to have both the English and Japanese language with the subtitle option in one file. I also want those episodes either in 1080p or 720p without it taking a ridiculous amount of space either.
I would really appreciate some help on that, thanks in advance!
Use DVDFab to rip the Bluray into mkv format. The program will allow you to rip both audio tracks and the subtitle track along with the video itself. Then you can use Handbrake to shrink the mkv to a more manageable size. Probably somewhere between 1.2 and 1.8 gigs if you shrink it to 720p dimensions.
Hmm okay, well i was actually trying out DVDFab just now, it works really great. The only problem is that i tried the mkv.remux option and i can select both languages, but after i rip it, when i play the file theres no audio.
So then, i tried settings other than mkv.remux and i can only select one language (a little dot that fills blue when selected) and then the quality and audio is good.
But i really am looking for a way to have both languages + subtitles in them. That would be just perfect. Not sure what i'm supposed to do to have both languages with the audio in. -
For videos i usually use Windows Media Classic or Windows Media Player with K-lite Codec Pack.
Just for info that's the error that pops up when using WM Classic if that can help:
C:\Users\Username\Documents\DVDFab\mkv\FAIRY_TALE_P1_D1\FAIRY_TALE_P1_D1.Title28.mkv ::a#0
Media Type 0:
Audio: 0xffff 48000Hz 6ch
AM_MEDIA_TYPE:
majortype: MEDIATYPE_Audio {73647561-0000-0010-8000-00AA00389B71}
subtype: Unknown GUID Name {0000FFFF-0000-0010-8000-00AA00389B71}
formattype: FORMAT_WaveFormatEx {05589F81-C356-11CE-BF01-00AA0055595A}
bFixedSizeSamples: 1
bTemporalCompression: 0
lSampleSize: 1152000
cbFormat: 18
WAVEFORMATEX:
wFormatTag: 0xffff
nChannels: 6
nSamplesPerSec: 48000
nAvgBytesPerSec: 0
nBlockAlign: 0
wBitsPerSample: 0
cbSize: 0 (extra bytes)
pbFormat:
0000: ff ff 06 00 80 bb 00 00 00 00 00 00 00 00 00 00 ÿÿ..€»..........
0010: 00 00 .. -
Well that weird, i just thought i'd try with Cyberlink PowerDVD and it works. I can choose the audio + subtitles perfectly fine. Wondering why the heck doesn't it work in WM Classic and WMP then?
EDIT: Just tried VLC Player and it works perfectly as well. Kind of strange, never had much trouble with WMC and WMP before that...
Can you rip Blu-Ray discs by using your PS3 without Linux?
By FallenAngelII in forum Blu-ray RippingReplies: 3Last Post: 16th May 2012, 08:43 -
Rip Blu-ray Movie to fit on two dual layer discs
By craigmack55 in forum Blu-ray RippingReplies: 10Last Post: 9th Dec 2010, 23:16 -
burning and playing blu ray/hd content onto discs onto dual layer discs
By julie_152 in forum Authoring (Blu-ray)Replies: 18Last Post: 21st Sep 2009, 14:36 -
Do all Blu-ray Discs contain DTS audio?
By delirial in forum Blu-ray RippingReplies: 3Last Post: 26th Jan 2009, 22:21 -
Can I rip Blu Ray Discs with LG Super Multi Blu-ray Disc and HD DVD-ROM Dri
By donpato in forum Blu-ray RippingReplies: 5Last Post: 5th May 2008, 17:05
