I have 3 files to merge/append. I tried using mkvmergegui, but because file 3 is in MPEG verses VC-1 for the other two, it complains. I've read about extracting the files with mkvextractgui, does this do 1:1 extracting?
Also, once the files are extracted, I'm not versed enough with mkvmerge to know what to do with the extracts.
Here is the mkvinfo on each file:
Code:video 1: |+ Segment tracks | + A track | + Track number: 1 (track ID for mkvmerge & mkvextract: 0) | + Track UID: 1422 | + Track type: video | + Default flag: 0 | + Lacing flag: 0 | + Codec ID: V_MS/VFW/FOURCC | + Video track | + Pixel width: 1920 | + Pixel height: 1080 | + Display width: 1920 | + Display height: 1080 | + CodecPrivate, length 71 (FourCC: WVC1, 0x31435657) | + Default duration: 41.708ms (23.976 frames/fields per second for a video track) | + A track | + Track number: 2 (track ID for mkvmerge & mkvextract: 1) | + Track UID: 10302 | + Track type: audio | + Default flag: 0 | + Codec ID: A_DTS | + Audio track | + Sampling frequency: 48000 | + Channels: 6 | + Bit depth: 24 video 2: |+ Segment tracks | + A track | + Track number: 1 (track ID for mkvmerge & mkvextract: 0) | + Track UID: 9347 | + Track type: video | + Default flag: 0 | + Lacing flag: 0 | + Codec ID: V_MS/VFW/FOURCC | + Video track | + Pixel width: 1920 | + Pixel height: 1080 | + Display width: 1920 | + Display height: 1080 | + CodecPrivate, length 71 (FourCC: WVC1, 0x31435657) | + Default duration: 41.708ms (23.976 frames/fields per second for a video track) | + A track | + Track number: 2 (track ID for mkvmerge & mkvextract: 1) | + Track UID: 29447 | + Track type: audio | + Default flag: 0 | + Codec ID: A_DTS | + Audio track | + Sampling frequency: 48000 | + Channels: 6 | + Bit depth: 24 video 3: |+ Segment tracks | + A track | + Track number: 1 (track ID for mkvmerge & mkvextract: 0) | + Track UID: 18507 | + Track type: video | + Default flag: 0 | + Lacing flag: 0 | + Codec ID: V_MPEG4/ISO/AVC | + Video track | + Pixel width: 1920 | + Pixel height: 1080 | + Display width: 1920 | + Display height: 1080 | + CodecPrivate, length 114 (h.264 profile: High @L4.1) | + Default duration: 41.708ms (23.976 frames/fields per second for a video track) | + A track | + Track number: 2 (track ID for mkvmerge & mkvextract: 1) | + Track UID: 16076 | + Track type: audio | + Default flag: 0 | + Codec ID: A_DTS | + Audio track | + Sampling frequency: 48000 | + Channels: 6 | + Bit depth: 24
I doubt you can merge mkvs with different video tracks.
Nick Burns: Make a copy of the files and drop them into Freemake Video Converter. If the dimensions are the same, it might append them all together, but it would recode to something else. Baldrick's method is probably the best. You could convert them all to the exact same specs and then take them to AviDemux and append them together and export them in copy mode without a further recode beyond what you did to get them all to match up. The FVC method might end up screwing up the audio.
All very new to this... would the conversion take place on the MKV or on the extract on the third video? I'm hoping I can convert #3 MPEG to VC-1. End result is to have one, albeit large, MKV file.
MKV with MKV Merge Unicode not compatible with LG BluRay Player
By klode in forum Video ConversionReplies: 3Last Post: 8th May 2011, 04:42 -
MKV Extract and Merge
By b1tbull in forum DVD RippingReplies: 2Last Post: 24th Aug 2010, 05:50 -
how to merge 2 mkv files by using MeGUI?
By newnews in forum Video ConversionReplies: 1Last Post: 6th Dec 2009, 07:51 -
Merge MKV Chapters??
By ron spencer in forum DVD RippingReplies: 2Last Post: 12th Sep 2009, 19:31 -
mkv merge
By runLoganrun in forum Newbie / General discussionsReplies: 0Last Post: 3rd Dec 2008, 07:53
