  1. Is there any way to use qtgmc instead of the built-in yadif filter? My video files are mpeg2, and that should be Directshow compatible. My avs ("A.avs") looks like this:
    SetMemoryMax(1600)
    SetMTMode(3,8)
    video=DirectShowSource("S:\TEST5\A.m2v")
    SetMTMode(2)
    video=video.AssumeTFF()
    video=video.QTGMC(Preset="Slow")
    video=video.SelectEven()
    video=video.Lanczos4Resize(1920,1080)
    video2=BlankClip(video,length=102)
    return(video+video2)
    and then the ffmpeg commandline looks like:
    ffmpeg -v verbose -y -i "S:\TEST5\A.avs" -c:v libx264 -preset slow -b:v 7550k -r:v 30000/1001 -x264opts open-gop:b-pyramid=strict:slices=4:qpmax=51:nr=250 -f rawvideo "S:\TEST5\A.264"
    Unfortunately all I get is "AFIFileOpen failed with error -2147221164. S:\TEST5\A.avs: Operation not permitted". Even when I just try to load the video in avisynth, no filters or anything:
    DirectshowSource("S:\TEST5\A.m2v")
    I get the same message. I am currently using the absolute latest version of ffmpeg (N-46469-gc995644 (Nov 5 2012)) with --enable-avisynth and --enable-libx264 and avisynth 2.58. I really need to be able to get the quality of qtgmc here, so how do I do this?
  2. can you preview the 1 line avs script in vdub or avspmod ? any error message ?
    You can use a non directshow source filter like FFVideoSource instead (directshow can cause problems with temporal filtering like QTGMC - it's not necessarily frame accurate and you can get mixed up/ out of order frames)
