I cannot get my files to show up in the transcode window it just says that if you can read this message transcode might not work.
What follows is from MediaInfo:
Format : MPEG-4
Format profile : Base Media / Version 2
Codec ID : mp42
File size : 25.0 MiB
Duration : 3mn 52s
Overall bit rate : 903 Kbps
Encoded date : UTC 2012-04-02 12:55:48
Tagged date : UTC 2012-04-02 12:55:57
Video
Format : AVC
Format profile : Baseline@L3.0
Format settings, CABAC : No
Format settings, ReFrames : 2 frames
Format settings, GOP : M=1, N=30
Codec ID : avc1
Duration : 3mn 52s
Bit rate : 702 Kbps
Width : 640 pixels
Height : 360 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.102
Stream size : 19.5 MiB (78%)
Language : English
Encoded date : UTC 2012-04-02 12:55:44
Color primaries : BT.601 NTSC
Transfer characteristics : BT.709
Matrix coefficients : BT.601
Audio
Format : AAC
Format profile : LC
Codec ID : 40
Duration : 3mn 52s
Source duration : 3mn 52s
Bit rate mode : Constant
Bit rate : 128 Kbps
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 44.1 KHz
Compression mode : Lossy
Stream size : 3.58 MiB (14%)
Source stream size : 3.58 MiB (14%)
Language : English
I have many of these that I am trying to put on bluray hopefully without to much alteration in the resolution(I know it's low).
Can anyone tell me what I am missing?
I should add that I have tried uninstalling then reinstalling these programs: AVISynth, FFDshow,multiAVCHD(with update).
Am I posting in the wrong forum? Should this be in video conversion?
Problem with multiAVCHD...
By hiimbored in forum Authoring (Blu-ray)Replies: 7Last Post: 2nd Jun 2015, 10:14 -
MultiAVCHD - Adware?
By Tiernan in forum Authoring (Blu-ray)Replies: 4Last Post: 18th Dec 2013, 18:46 -
multiAVCHD movie only
By wulf109 in forum Blu-ray RippingReplies: 8Last Post: 3rd Nov 2010, 08:52 -
Which value I need to crop in multiAVCHD
By NZBPirates in forum Video ConversionReplies: 0Last Post: 16th Sep 2010, 14:26 -
multiAVCHD and HD-DVD
By wulf109 in forum Blu-ray RippingReplies: 1Last Post: 19th Mar 2010, 09:05
