I have a TS file (video: MPEG2, audio: AC3) that I know has several errors around timestamp 4:14.000. As far as I can tell, ~256ms of audio was lost, so now it comes early for the rest of the clip. How would I go about using ffmpeg and the -vsync and -async/-asyncts functions to fix this? I've looked at the documentation, but I'm pretty new to video editing, so I really need some clarification. I have tried multiple combinations of the -vsync and -async commands, and it fixes the initial delay at the beginning, but the fix at 4:14.000 is more like 1.5 seconds of silence instead of the true ~256ms- it just freezes the video and adds all that silence. I can manually edit the AC3 file to add 256ms of silence at 4:14.000 using delaycut, and restitching the pieces back together, but this would be extremely mundane to do if there are multiple errors in the TS stream (which I have found with others). Any help creating a functional command line would be appreciated.
Results 1 to 1 of 1
How to convert DV avi files to DVD ready MPG files with Win7 powershell.
By findus in forum User guidesReplies: 5Last Post: 19th Dec 2011, 16:42 -
Use .MTS files in Final Cut Pro while keeping original dates in the files
By Winterburn in forum MacReplies: 3Last Post: 18th Aug 2011, 16:21 -
VirtualDub - resyncing audio?
By Jonz in forum Newbie / General discussionsReplies: 7Last Post: 28th May 2011, 16:01 -
Why doesn't MKV files play BD PGS/sup files in software or hardware players
By cal_tony in forum SubtitleReplies: 2Last Post: 22nd Mar 2010, 12:10 -
Resyncing a recently bought DVD
By Worst.episode.ever in forum DVD RippingReplies: 3Last Post: 10th Mar 2010, 02:59
